586,535 active members*
3,150 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Fagor 8055 Manual Tool Change PP for Fusion 360
    Jul 2020
    Hello all,
    I have been struggling with this for a while now. Does anyone out there have a Post Processor for Fusion 360 that will work with the 8055 without an ATC? The PP that came with Fusion is for a machine with a tool changer for which I don't have so the post is looking for the changer "M6". I have tried to modify the post, but was not able to.
    I tried the manual post that I fond on the Autodesk sight and although it will run the program in its entirety, it has no ability to move to a tool change position, nor let me move and change to a subsequent tool. What I mean by that is I can start the program, it will cut with the first tool, dwell and if I simply push cycle start it will continue without a tool change. I am new at this so it is possible I am doing something wrong, but I really don't think so. Autodesk support was trying to help, but ultimately said it was likely a Fagor thing. Hoping someone can help since I can't use the machine if I want to use Fusion for the CAD CAM.
    Steve
    May 2022
    20
    Quote Originally Posted by Shop-Dog View Post
    Hello all,
    Steve
    Hi Steve
    I’d like to help you sort out your post processor problem. I specialise in editing posts for Fusion 360. You can email me directly at [email protected]
    Kindly
    Michael
  1. Fagor 8055 Manual Tool Change
    By Dirkfra in forum Fagor Automation
    Last Post: 09-11-2023, 02:37 AM
  2. Fusion 360 post with tool change request
    By Sharab85 in forum Milltronics
    Last Post: 10-01-2021, 05:38 AM
  3. Tormach Fusion 360 Post - Why the M1's before tool change
    By KSky in forum Tormach PathPilot™
    Last Post: 08-18-2016, 07:51 PM
  4. Manual Tool Changes - PathPilot / Fusion 360
    By nickfabb in forum Tormach PathPilot™
    Last Post: 03-17-2015, 01:22 AM
