586,138 active members*
3,492 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Need some tutoring for the 440... feeds/speeds etc.
    Dec 2021
    Hi I just got a used 440 yesterday and I need some help with Feeds and Speeds and other settings. I am willing to pay someone for their time. I have a few small jobs I need to do but have no idea where to start with settings. Also, I use Fusion 360 and I have some questions about those settings as well. I come from a router background so I would prefer to learn from someone with experience and pay for that time so I can get started right away with some success. Please let me know if you can help
    Re: Need some tutoring for the 440... feeds/speeds etc.
    Any decent cutting tool manufacturer will have their recommended speeds and feeds on their site which usually offers a good start point . Start at the lower recommendations and you should do ok as long as the programming is reasonable . A difference I'm sure you already know is it's better to ramp a tool into the work piece on a mill vs plunging which would be more common on a router . It can be argued that a center cutting tool is made specifically for the ability to plunge , but vibration on a lesser rigid machine can and will damage a tool
    There is a pcnc440 facebook group which might be worth joining . there is a lot of info on there and it'll give you a good indication of the mill's capabilities and where it may lack in them
    Dec 2021
    Do you have a link for that FB group? I searched and could not find it
    Jun 2005
    656
    Try FS-wizard and see what it suggests and dial it back from there. Check the RPM and HP numbers to see if your machine can do them. https://zero-divide.net/fswizard
    - - - Updated - - -
    Nov 2022
    12
    Provencut is lauded as having specific F&S numbers for a 440.
  1. Feeds and Speeds
    By brokellermann in forum Tormach Personal CNC Mill
    Last Post: 08-04-2015, 09:22 PM
  2. Speeds and feeds!!!
    By rsaulus in forum Hobby Discussion
    Last Post: 05-21-2014, 02:07 AM
  3. speeds and feeds
    By ponchosb77 in forum CNC Tooling
    Last Post: 02-25-2011, 11:12 PM
  4. speeds and feeds
    By bdrmachine in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-12-2008, 02:15 PM
  5. Speeds and Feeds
    By CLP CORP. in forum WoodWorking Topics
    Last Post: 12-07-2007, 07:38 PM
