Hello,
You think a Shapeoko 5 Pro or PM-25mv will be good to make 0.6mm sitting saw cuts to make PC water cooling blocks?
I want to get the 5 pro because it's easy to assemble and have great tolerances but I think it's not rigid enough.
The PM-25mv will require a lot of work and hassle to convert to CNC and modifying it to accept a high RPM spindle.
Basically need to make microfins such as the photo I attached to make CPU/GPU water blocks.
Here is a video of what I am trying to achieve:
https://www.youtube.com/watch?v=613qkiIrXFM&t=1s
He is using a BF-20 Vario with a Chinese spindle, he also made the CPU water block of the picture I attached.
Here is a complete thread forum of him making a high precision water block with many microfins about 10 years ago:
Build a high end waterblock on a cnc machine
I am not sure what kind of spindle I should use. Have any recommendation for a hobbyist level spindle?
Here is the spindle I need (used by the person who was using 0.2mm saw blade) but not sure what kind it is:
https://www.youtube.com/watch?v=A6z9y_QJO8E
Thanks for any advice.
