Is there any other programs other than DNC that i can use to transfer files from mastercam to the controler using a com1 port?
071110-1433 EST USA
LT1TRUCK:
Most communication programs allow selection of at least COM1 and COM2.
Mastercam prior to X included Cimco Edit. If you find its location you can run it independent of Mastercam, otherwise run it from within Mastercam.
I am not familar with a program with the name DNC. What is wrong with this program that you want to use a different program?
Just remember you need a serial port to dnc. If you only have usb ports buy a usb to serial converter, or get a serial card for your pc.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Thanks guys, i didnt know that cimco could transfer files through rs. Thanks again.
