586,754 active members*
7,537 visitors online*
Results 1 to 8 of 8
    May 2007
    163
    Thread milling
    Any one done any thread milling yet!
    Dec 2006
    34
    I thread mill every day and have had tremedous success.No more broken taps to burn out and complete size control.
    May 2007
    163
    Witch type of tool are you useing? Thare are 3 to choos from, as far as I know.
    Dec 2006
    34
    I use solid carbide for all tapped holes smaller than 1/2.I either buy Carmex or threadmillusa.For larger holes I use Vardex or Stellram.If you need help programming their websites usually offer an excel spredsheet that you enter your parameters and outputs Gcode that you can cut and paste into your cnc program.
    Feb 2007
    246
    Are you using straight or spiral flute thread mills?
    I have never done it except with a single point tool, and I am going to do some pipe threads.
    Live free or die
    Dec 2006
    34
    I ues straight fluted.I have never milled a NPT thread but I don't see any problems.
    Jun 2007
    168
    If your budget is limited, you should go for one-flute thread mill, very versatile but long to cut.
    Feb 2007
    246
    I tried doing some 3/4 and 1/2 NPT with no problems at all, very satisfied. Hand tapping is for suckers!
    I used an Advent thread mill with a single flute indexable carbide insert, material was 316 stainless.
    I recommend giving it a try, I used the software from the Advent and it work perfectly.
    Live free or die
  1. Thread milling help!
    By asjad in forum CNC Machining Centers
    Last Post: 09-21-2008, 04:47 PM
  2. thread milling
    By fourperf in forum Fadal
    Last Post: 03-11-2008, 01:14 AM
  3. 0M-Thread milling?
    By mikul in forum Fanuc
    Last Post: 12-06-2006, 06:56 AM
  4. thread milling
    By STS_Kevin in forum Daewoo/Doosan
    Last Post: 11-29-2006, 01:50 AM
  5. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
