586,546 active members*
3,382 visitors online*
    Modify SolidCAM PP for Elexa G84
    Hello. I have a problem in my SolidCAM 2014 with how it writes the G84 gcode.
    The G84 tapping cycle of the Elexa control of my 3 axis milling machine needs to be written in such a way that;
    S is the spindle speed
    and F feed is the tap pitch in microns.
    The control then calculates the real feed itself.
    In the SolidCAM Tool library editor I can write the tap pitch and speed of the spindle, but the feed is calculated and can't be entered manually.
    So for example if I set the tool spindle speed to 300 and the pitch is 1,25mm, the feed is calculated to 375
    So the gcode generated is;
    S300
    G84 ... ... ..... F375
    G80
    But the correct one should be;
    S300
    G84 ... ... ..... F1250
    G80
    Now I have to manually edit the gcode in order to make it work properly. So far no taps broken...
    So I wonder if there is any possibility to modify:
    1) the way the SolidCAM tool library editor calculates the feed
    2) modify the PP that instead of the 'feed' parameter writes the 'pitch' parameter (unavailable)
    Any hints?
    Thank you.
    Mar 2016
    325
    Re: Modify SolidCAM PP for Elexa G84
    Easiest way is to edit pp and add equation for feed value (its f/s*1000) it should work anyway.
    Values for f, and s are variables that u can easy find in gpp file.
    As for using pitch directly- U would need to find that variable in Vmid, and i'm not sure if there is any actually, cause pitch of the taper is probably not used in gcode generating.
    Hi, thanks for the reply.
    It does indeed solve the issue!
    Thanks a lot.
  1. Replies: 2
    Last Post: 09-07-2023, 01:39 PM
  2. If Any one Need Help in cnc machine Ferrari and Elexa & Tnc controll just Write here
    By hosamsoft in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2020, 08:06 PM
  3. Solidcam Error - Can't uncompress CAM-part. Check SolidCAM temporary folder
    By scottbryce in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-28-2018, 03:29 AM
  4. Elexa Post Processor
    By jvidal in forum Visual Mill
    Last Post: 11-24-2013, 11:17 PM
