587,033 active members*
3,348 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > KOMO VR 510TG CNC Fanuc 210i Post Processor Needed!
Results 1 to 1 of 1
    Dec 2023
    Exclamation KOMO VR 510TG CNC Fanuc 210i Post Processor Needed!
    I have been trying to find resources online, but have not been able to find anything relevant.
    For context, I have a KOMO VR 510TG with a Fanuc 210i controller.
    I use Vectric VCarve Pro 11.0 software and am having trouble getting proper post-processor code. The current preset that VCarve offers is inefficient (KOMO 510 Innova inch nor KOMO ATC mm works . For example, to cut a square when the machine turns the corner, it hovers and takes many micro steps to make an arc instead of just moving in two perpendicular lines.
    If anyone has the same machine and is kind enough to provide the PP code that would be perfect. Any other advice/help would also be greatly appreciated.
    Thank you in advance
    May 2022
    20
    Quote Originally Posted by escapetrailer View Post
    Hi there
    I specialise in writing custom post processors. I’ll be able to help you edit your post and ensure it works the way you need it to. You can contact me directly at [email protected]
    Regards
    Michael
