In my Cam Software ( Fusion 360 ) I typically use a nominal tool diameter ( example for my 1/2" would be .50 " ) verses the exact measurement of the tool at that point in time.
What I would like to do is make my adjustments on my Haas classic controller.
So my understanding is that in Fusion I change the compensation type to " In Controller "
My question is my setting on the Haas.
For this example In Fusion my tool diameter is set at .500 "
My actual tool diameter on the machine after probing is .5015"
I believe my machine compensation is setup for diameter verses radius
So would I set my wear compensation for that tool as a positive .0015?
Second question, since my tool probing already put the .5015 value in for the tool diameter do I just leave that in there? ( In other words is the machine using that value for calculating, or is it just to reference?
Thanks for any advice on this....
Kent
