586,655 active members*
2,895 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Maxed out number of programs in 0-M
    Nov 2007
    29
    Is there any way to get around the 63 program max in the 0-M control?
    I have lots of small sub's leaving plenty of memory but need more program numbers.
    24223
    You could try Para 915 bit #7 1xxxxxxx, 200 registerable programs, It may require hardware depending on how much memory you have now.
    Al
    Nov 2005
    274
    Try 903.5
    Try 903.5 if Al's wont get you there, This takes you to 125 #'s and in most cases this is the next step up and rearly requires a hardware upgrade
    Bluesman
    Nov 2007
    29
    Thanks for the great help
    Thanks!
    Al's parameter info seems to have worked. Received error 100 until turning off and restarting then had 200 program numbers available. This forum is a great asset to CNC'rs.
    Greatly appreciated
    :cheers::cheers::cheers:
  1. Number Counter
    By CI_182 in forum G-Code Programing
    Last Post: 09-01-2007, 09:41 PM
  2. Replies: 1
    Last Post: 08-22-2007, 06:39 PM
  3. omit line number
    By asjad in forum Mastercam
    Last Post: 05-10-2007, 12:18 PM
  4. Dx-32 auto N number for you
    By jtree83 in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2005, 07:28 PM
