586,744 active members*
4,863 visitors online*
    Apr 2005
    108
    Panasonic servo
    I have Panasonic servo drive 2kw can I connect it to
    750w Panasonic motor
    Jun 2010
    4256
    Re: Panasonic servo
    Yes.
    Just limit the voltage and current. The servo drive should allow that.
    Cheers
    roger
    Apr 2005
    108
    Re: Panasonic servo
    Thank you
    Apr 2005
    108
    Re: Panasonic servo
    I have Panasonic A5 servo drive the type is MEDHT4430NA1
    This servo has the X4 plug smaller then in the drawing
    Is someone can get me the drawing of this plug
    Nov 2013
    4449
    Re: Panasonic servo
    do you have the manual of the drive? If so there should be a listing of the compatible servos. If the plugs are different it may well be that
    your servo is not compatible with the drive.
    Is there a reason that you want to use a drive and a servo that are not perfectly matched. I know its very tempting to get a second hand servo, there seem to
    be so many to choose from, but then you have to find a matching drive and that's a whole bunch harder. The drives tend to blow up eventually, so the servo gets sold
    while the drive is scrapped, ergo lots of servos but few drives.
    Craig
  1. Replies: 6
    Last Post: 11-20-2015, 07:11 PM
  2. Panasonic AC servo driver
    By croco85 in forum Servo Motors / Drives
    Last Post: 07-25-2015, 03:21 PM
  3. Panasonic servo Vs Yaskawa servo
    By saratbabu in forum Servo Motors / Drives
    Last Post: 05-03-2013, 12:56 AM
  4. Panasonic servo
    By gorders1 in forum Servo Motors / Drives
    Last Post: 01-26-2013, 04:09 AM
  5. Panasonic AC Servo Motor....I think????
    By hansenmick in forum Servo Motors / Drives
    Last Post: 03-27-2007, 06:10 AM
