587,040 active members*
2,873 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo motor - SIMOTICS S-1FK2 model : 1FK2204-5AF00-0MA0
    Nov 2023
    Arrow Servo motor - SIMOTICS S-1FK2 model : 1FK2204-5AF00-0MA0
    Hello
    I have a Siemens servo motor model: 1FK2204-5AF00-0MA0, which makes noise.
    I am going to change the ball bearings.
    I took it apart, but I can't remove the optical encoder disk, apparently it's stuck...
    Is there anyone who knows this type of servomotor, here are some photos.
    thanks in advance
    Attached Thumbnails Attached Thumbnails servo motor siemens 1FK2(1).jpg   servo motor siemens 1FK2(2).jpg   servo motor siemens 1FK2(3).jpg
    Re: Servo motor - SIMOTICS S-1FK2 model : 1FK2204-5AF00-0MA0
    Quote Originally Posted by clinitechtunisie View Post
    Hello
    thanks in advance
    Forgot to attach the photos?
    24223
    You do know if you remove the encoder you will have to re-align the commutation tracks when re-fitting!
    Jan 2022
    5
    It is best not to remove the encoder yourself, as it may not be possible to restore. It seems that Siemens has repair service.
