586,508 active members*
2,971 visitors online*
    Oct 2023
    Intermac Master 33 Axis Calibration
    I’ve got an Intermac 33 CNC where the a axis has travelled way past where it should, the fault codes on screen say that it has activated both the hardware up and down limits, which it hasn’t only one of the plungers on the limit switch is active, which is the front most one due to its position and the flags that activate the limit, and also “software end of range UP”. It is physically tilted pretty much 45 degrees anti clockwise from home. I need to know how to get it to drive back to being straight, which it won’t manually. And then how to calibrate the axis. Any help thank you
    Oct 2023
    The following fault codes appear on screen;
    AXS 629- Axis at the UP hardware limit switch. Axis A
    AXS 630 - Axis at the DOWN hardware limit switch. Axis A
    AXS 336 - Axis at software end of range UP. Axis A
  1. machine intermac master 33
    By htm23 in forum CNC Machining Centers
    Last Post: 11-07-2021, 12:03 AM
  2. intermac master bevel
    By Giglesias in forum Glass, Plastic and Stone
    Last Post: 06-23-2013, 07:46 PM
  3. Intermac Master Bevel
    By Glass in forum Glass, Plastic and Stone
    Last Post: 07-13-2011, 06:42 PM
  4. INTERMAC MASTER MAXI
    By A Teixeira in forum Glass, Plastic and Stone
    Last Post: 01-28-2011, 06:38 PM
