586,461 active members*
4,140 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobcad-Cam Version 30 selecting lines issue
    Mar 2014
    26
    I have Bobcad-Cam version 30 and had it installed on a Windows 10 computer and had to reinstall it on a new computer using Windows 11. Since installing on the new computer to be able to pick any lines I have to turn off my dimensions layer or I can not select anything. My engineer creates the drawing files in auto cad and saves them on a server, I then load the file off of the server. This has worked great for years without any issues. Is this a Windows 11 issue or is there a setting I need to change in Bobcad now that I am using Windows 11 so that it will let me select lines without turning off my dimensions layer?
    May 2016
    20
    Re: Bobcad-Cam Version 30 selecting lines issue
    I am having the same issue with V30. Did you find a solution?
  1. BoBCad Version 30 G code issue
    By bcnu in forum BobCad-Cam
    Last Post: 03-19-2018, 09:04 PM
  2. BobCad/Cam selecting....
    By ckovacs in forum Tutorials
    Last Post: 03-14-2016, 06:46 PM
  3. Bisect lines BobCad Cam V24
    By flesvik in forum BobCad-Cam
    Last Post: 05-30-2015, 07:40 PM
  4. Problem Selecting Tool when Tapping in BobCAD-CAM
    By superart1 in forum BobCad-Cam
    Last Post: 11-13-2013, 06:06 PM
