Good Afternoon,
I use an AXYZ PanelBuilder router and I am attempting to cut an aluminum card holder with these parameters:
Aluminum Sheet: Thickness: 1/16"
Coolant On
Router Bit: 1/8"
Feeds and speeds:
RPM: 22,000
Feed Rate: 35 ipm
Plunge Rate: 20 ipm
Pass Depth 1/8"
However, when I begin the cut the aluminum chips don't shoot out via the bit flute instead they get re-welded into the aluminum sheet itself. Is there a solution to this?
Thank you
