586,817 active members*
8,369 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > NUM 1040 Enable editing of machine parameters
    Aug 2022
    7
    Hello,
    I would like to change some of the machine parameters with the NUM 1040 controller.
    From information that I gathered that is done via “CN UTILITY -> 0 ACCESS TO UTILITY PROGRAMMES” but when I want to select this utility in the menu, nothing happens (see image).
    Is there any general lock or do I need to change some access rights to activate this utility?
    How can that be activated or “unlocked”?
    Any help appreciated!
    Thank you for your time!
    Mar 2024
    9
    Re: NUM 1040 Enable editing of machine parameters
    Hello Cimrez,
    Some PLC applications can lock out access to utilities. If you are willing to share what type of parameter changes you had in mind I may be able to help.
  1. Need help.. NUM 1040
    By Russel23 in forum Novakon
    Last Post: 08-17-2018, 02:21 PM
  2. Realmeca C2 NUM 1040 parameters
    By skander9999 in forum Controller & Computer Solutions
    Last Post: 11-26-2016, 12:05 PM
  3. CNC NUM 1040
    By RAVENEXTREME in forum Controller & Computer Solutions
    Last Post: 01-14-2016, 03:19 AM
  4. NUM 1040, AlphaEdit
    By Nipper in forum Controller Cards
    Last Post: 07-22-2011, 10:18 PM
