586,369 active members*
3,189 visitors online*
    Sep 2005
    72
    noise in bridgeport series one
    ok i think i have fixed my machine today,it had a lot of noise in the pulleys . i changed the timeing belt, it is quieter but when i crank up the speed to 1600 or more the pulleys get louder does not sound normal. my question is are they suppose to run like a drill press smooth or is this normal, it is a 1980 model.
    thanks alex
    Nov 2004
    3028
    You cannot expect a 27 year old mill to sound like a new one. But you can get it close.
    As I said. The most common problem is the vari disc bushings worn out. Check that first.
    Then possibly the clutches (teeth/drive for high gear).
    George
  1. Noise in Bridgeport 2J head (audio file included)
    By daytrader in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2016, 07:03 PM
  2. Another Bridgeport Series 1
    By dougputt in forum Bridgeport / Hardinge Mills
    Last Post: 09-07-2007, 12:46 AM
  3. Bridgeport Series 1 CNC ID
    By markhas in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2006, 04:06 PM
  4. Bridgeport series 1 or 2 ??
    By drill in forum Bridgeport / Hardinge Mills
    Last Post: 11-28-2005, 03:17 AM
  5. Bridgeport Series 1
    By CRAZYRICH in forum MetalWork Discussion
    Last Post: 07-28-2005, 01:54 AM
