587,058 active members*
3,985 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Fusion 360 4th Axis Post Processor
Results 1 to 9 of 9
    Feb 2007
    68
    I've got my fleabay 4th axis working well on my RH19 Cent7. Just looking for a post that runs the 4th axis with F360. It looks like I need to modify my own or find one that's been done correctly. Apparently I have to modify something to simulate with (generic) machine as well.
    Anybody gone there yet?
    Nov 2013
    4472
    Re: Fusion 360 4th Axis Post Processor
    many of the Fusion supplied post processors are actually already four and sometimes five axis capable. All that is required is to edit the post to 'turn on' the axes you want.
    As an example I have been using the Mach4 post for several years, and then fitted a fourth axis. With the help of the Autodesk Fusion team it was a fairly simple matter to turn on the
    fourth axis feature of the post, its already there, just waiting to be activated. So I now use the identical post., its just now four axis activated.
    Ask Autodesk if the post has a fourth axis function.
    Craig
    Feb 2007
    68
    pretty sure the milltronics post doesn't have the switch to turn on the 4th.
    Nov 2013
    4472
    have you opened the post and inspected the code?
    Craig
    Feb 2007
    68
    sure
    It's like learning another language.
    Nov 2013
    4472
    I jjust opened the Fusion supplied Milltronics post and found this:
    Code:
    function defineMachine() {
      var useTCP = true;
      if (false) { // note: setup your machine here
        var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120, 120], preference:1, tcp:useTCP});
        var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], preference:0, tcp:useTCP});
        machineConfiguration = new MachineConfiguration(aAxis, cAxis);
        setMachineConfiguration(machineConfiguration);
        if (receivedMachineConfiguration) {
          warning(localize("The provided CAM machine configuration is overwritten by the postprocessor."));
          receivedMachineConfiguration = false; // CAM provided machine configuration is overwritten
      if (!receivedMachineConfiguration) {
        // multiaxis settings
        if (machineConfiguration.isHeadConfiguration()) {
          machineConfiguration.setVirtualTooltip(false); // translate the pivot point to the virtual tool tip for nonTCP rotary heads
    So I rather suspect the post has both four AND five axis capability and TCP capability as well, although I'm less sure about this last feature. Either way you need to enquire of Autodesk how to activate
    the fourth axis.
    Craig
    Nov 2013
    4472
    when I faced the prospect of editing a post I too was overwhelmed, but I was provided a link to a training document. Its a big and heavy read but
    I was able to glean enough that I was able to do what I needed. Its 288 pages, but don't worry, its only the first 287 that are the worst.
    I don't have the link but it is an official Autodesk publication.
    I'm just finishing a fifth axis trunnion for my machine. I know the Mach4 post does not have five axis capability....so over the next few months I'm going to have to write my own.....
    and won't that be fun! Just like an in-grown toe-nail.
    Craig
    Feb 2007
    68
    Thanks for the replies. The older I get the more frustrated I get that I was the guy that drove a 442 and not something with a small block Chevy while working at a speed shop that sold SBC go-fast parts by the truck load for pennies on the dollar compared to Olds performance parts. Now I'm "driving" a Milltronics instead of a Haas.
    Autodesk sends me to a page full of people willing to charge me by the hour to remedy my situation while offering posts for "small block chevys" for the price of admission...... which I pay every year.
    Of course, my first F360/4thAxis project isn't something I can easily produce on my B-port with an indexer.
    To beat all, this isn't a hobby. My Milltronics just sits idle while I make one off parts using my b-port with prototrak and hand files. Makes me wish I bought a Haas, but I've never run one. I did learn another odd ball machine at another job, Mazak. There's another foreign language that's not used around the world.
    Attachment 497492
    Nov 2013
    4472
    if you want to do it for free, you can. All the required code is built in, you just have to roll up your sleeves and get stuck in, its not that hard.
    If you can't or won't then there are companies whom specialize in this stuff, but you pay them. The good news is that the post is already loaded with the code you need, you just need someone to turn it on,
    and this could be done quickly, easily and cheaply, I would guess under $500.
    It took me a week of reading and messing around and quite a few emails to Autodesk but I got my post running, and it cost nothing except the effort on my part to learn what to do.
    Haas has their own posts, and they to have to be activated to get them to work and often are tied or keyed to Haas fourth and fifth axis hardware. You don't suppose Haas got to be as big as it is WITHOUT charging people
    bigtime? Don't be deluded...of course they do.
    Instead of moaning about it either get stuck in and do it yourself or find a reasonable soul to help you. It'll pay for itself in short order.
    Craig
  1. Fusion 360 Post Processor for 5-Axis Roeders RXP60 5-Axis machine
    By shirinshah in forum Autodesk Post Processors
    Last Post: 09-15-2020, 12:28 AM
  2. HY 6040 5-axis cnc post processor for fusion 360
    By KhunKyawOo in forum Chinese Machines
    Last Post: 03-20-2020, 06:25 AM
  3. Replies: 1
    Last Post: 11-23-2017, 10:29 AM
  4. 4th Axis and Fusion 360
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 11-28-2016, 07:24 PM
  5. fusion 360 post processor
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 03-20-2016, 08:20 PM
