586,268 active members*
3,718 visitors online*
    Deflection problem with 20mm Aluminum Rails
    Hi all, I hope you can help!
    I'm planning a router sled currently to flatten some large slabs, I'm thinking of using 20mm aluminum cross-rails within which the router would be attached. My question is with the amount of deflection that might be produced from these rails, I've done some calculations using round bar deflection calculators available online and I'm getting the results out to be around 25/26mm deflection for a 2m long rail.
    However, this calculation is for just one rail, whereas the sled would have two, also a "point-load" probably isn't the right term for a router spread over 4 cars on 2 rails...
    Also note that I don't necessarily require an exact answer to the calculation, my question is really, would 2 x 2000mm(length) x 20mm(diameter) aluminum rails, clamped at either end, support a 1/2" router plus a few components without a noticeable amount of deflection? I suspect they would sag a little but it's only a guess.
    Your help is greatly appreciated!
    Jun 2005
    1730
    Re: Deflection problem with 20mm Aluminum Rails
    Quote Originally Posted by johnnyhawkins View Post
    Big Heavy 1/2" routers will make it sag in the middle with 20mm rails. You might want to go to 25mm rods or better yet, standard flat linear rails which can be fully supported underneath the rail the entire length. Flatten slabs is not a critical application as you will work them with sanders after you finish roughing them. So probably not that critical.
    Jul 2018
    6355
    Hi Johnny - Yes a 20mm aluminium section over 2m will sag alot. Go to a metal supplier or the local hardware that sells 2m lengths and just put them across something and push in the middle, the deflection will surprise you. Peter
    Thanks for the prompt responses guys, appreciated. Think I'll have to visit a metal shop!
    Nov 2013
    4387
    even with steel you'll get too much deflection.
    If you calculated 25mm deflection for a 20mm diameter aluminum section, and that sounds about right, steel is tree times stiffer than aluminum so for the same 20mm steel section
    you'd get 25/3= 8.88mm deflection, which is still too much.
    Craig
  1. Deflection calculation - 20mm rod
    By wm_crash in forum Mechanical Calculations/Engineering Design
    Last Post: 07-04-2011, 06:51 AM
  2. 15MM vs. 20MM RAILS
    By woodworker2 in forum DIY CNC Router Table Machines
    Last Post: 09-21-2010, 03:13 PM
  3. 16mm vs. 20mm supported linear rails...
    By WilliamD in forum DIY CNC Router Table Machines
    Last Post: 12-20-2008, 12:37 AM
  4. Why do some people say you need 20mm rails???
    By Mr.Nerd in forum DIY CNC Router Table Machines
    Last Post: 06-29-2006, 01:05 AM
