586,512 active members*
3,380 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Very basic question - how do i wire up a plug to my 45XP?! (CE version)
    Sep 2023
    Apologies if this is completely obvious but how do I wire up a plug to my 45XP? There are four cables & I need to wire it up to a 3 pin plug (UK)?
    Thanks so much in advance!
    Aug 2023
    Re: Very basic question - how do i wire up a plug to my 45XP?! (CE version)
    Are you 100% sure this is a single phase unit? Is there a spec plate on the back?
    Nov 2013
    4422
    Hypertherm offer the XP45 in both single phase and three phase configurations. As 400XD suggests this is supplied by the spec plate. Hypertherm are very careful to present that type of information
    on the manufacturers plate and to international standards.
    I worked for a welding supply company and serviced Hypertherm for seven years, including approximately annual training sessions of two and three days each by Hypertherm Engineers/Technicians sent all the way out
    to New Zealand for that purpose.
    The problem with the single phase variant was that the color scheme followed US practice (Black, White and Green-Yellow) whereas in New Zealand we follow IEC colors (Blue, Brown, Green-Yellow)
    and that the conductors were large, say 4mm2 which meant that it was a battle to fit a single phase plug as most plugs are designed for only 2.5mm2 conductors.
    Hypertherm are damned good, solid plasmas....best on the market by my estimation.
    Craig
  1. New CNC from China Need to hook up 220v wire and plug, to plug in.
    By zlswain in forum CNC Machine Related Electronics
    Last Post: 06-20-2019, 02:10 PM
  2. hypertherm powermax 45xp Ohmic sensor question
    By funding33 in forum Hypertherm Plasma
    Last Post: 06-06-2018, 01:36 PM
  3. New DHC2, 45xp, have ohmic question
    By adown in forum PlasmaCam
    Last Post: 01-13-2017, 05:20 PM
  4. connecting wire and plug to 220v 3phase vacuum pump Please help!
    Last Post: 11-05-2013, 08:58 PM
  5. Basic Wire Machine
    By chet470 in forum EDM Discussion General Topics
    Last Post: 09-26-2011, 04:35 PM
