586,537 active members*
2,891 visitors online*
Results 1 to 13 of 13
    May 2007
    15
    CNC Gemstone Cutting
    Does anyone know of anyone doing CNC Gemstone cutting, and or any CAD/CAM software that has the complex gemstone facets preloaded? Or if you have any ideas of what one could do with the software, Im just looking for ideas on my next project.
    May 2006
    2420
    It is something I would like to try, just have to finish a few projects first, as for the design's, it would be a simple thing to code by hand, for instance the pavillion on a SRB is simply 8 main facets and 16 girdle facets, not counting the girdle rounding itself but easy enough to do with two angular axis's and a third depth of cut axis, possibly a sweeping motion while cutting would be a good idea as well.
    I think the tricky part would be the polishing, but with a little trial and error I think a solution would evolve.
    Russell.
    Feb 2007
    4553
    Gemstone
    Matt,
    Mini-Tech has a customer that machines Moissanite there name is Charles Colvard
    Mini-Tech might have pictures of the process, this is there website:
    http://www.minitech.com
    Hope the info helps.
    Jeff Alessi
    [email protected]
    Mar 2007
    7
    Smile Hello
    Quote Originally Posted by Matt29c View Post
    I am looking for same thing.
    Mar 2010
    4
    i am looking for the same thing
    Oct 2009
    32
    hi guys..i also want to cut gemstones,but i wanna engrave onyx and such stones,maybe torquouise, i use rhino and artcam for design... do u guys know what kind of endmill i should use? some diamond tools taht i have peel of diamant layer too quickly...you know any good company taht makes it? thank You
    Jun 2009
    4
    CNC making Jewel
    Hi guyz! Is there really a CNC that can cut Gemstone? i've been looking for one all over the internet with no success...Would it be possible to make one...Im of the impression that the manual Faceting machines and the other accessories that come with it work better than a CNC, hence the luck of that machine..Anyone know of any CNC that's used for making the Jewel out of the Gemstone..?
    May 2011
    This is an old thread but I’m new to this site, and I have been cutting gemstones for about 20 years, mostly with an UltraTec.
    Years ago Facetron was working on a CNC faceting machine. I watched it work at the Tucson gem show, and talked to Jarvi about the machine. He admitted that polishing had to have a human eye. Jarvi is gone now and I don’t know whatever happened to this project? Maybe someone at Facetron would know?
    With a lot of gemstones having different harnesses on different axis doing a good job would be VERY hard.
    On a side note I’m looking to make some Faceting Machines at some point. Most if not all of the patents have run out on these machines so making clones should be easy, and UltraTec was quick to jump on the curved faceting bandwagon just before Polymetrics patent ran out so I say turnabout is fair play.
    Oct 2006
    210
    Vaderspade, I sent you a PM about this. I have some CNC faceting machines.
    Aug 2016
    1
    Re: CNC Gemstone Cutting
    This thread is a bit old but I thought I would reply anyway. I worked with Norm Jarvi on the Facetron CNC machine. It was more than 20 years ago. I designed all the software and electronics. Norm did the mechanical portion of the machine. Over the past year, I've been working on a new CNC gemstone cutter. I have a prototype machine. It is coming along pretty well. Automated gemstone polishing is tricky but very possible. I hope to have a final implementation by the end of 2016. As of now it is just a hobby project.
    Sep 2005
    1195
    Can you send me a link to your website ?
    Oct 2016
    1
    Wow I'd be very interested in this! I know a company called Wild & Petsch have been using an automatic gem cutting machine for sometime.
    Sent from my iPad using Tapatalk
    Jul 2017
    1
    Any progress on this?
  1. Replies: 0
    Last Post: 05-06-2014, 02:41 AM
  2. Cutting Quality Makes TubeTailor I Tube Cutting Machine Stand Out
    By Steel Tailor in forum News Announcements
    Last Post: 04-18-2014, 02:17 AM
  3. Replies: 0
    Last Post: 12-05-2013, 09:53 AM
  4. LIMAC fiber laser cutting machine for stainless steel cutting video
    By limacchina in forum Fiber Laser Cutting Topics
    Last Post: 05-05-2013, 05:24 PM
  5. Replies: 0
    Last Post: 01-26-2010, 02:53 AM
