586,898 active members*
3,377 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Measuring Circumference using alphacam
    Aug 2023
    Hello,
    How do I dimension a circumference using alphacam. It is not in the dropdown.
    Thanks Ben
    Dec 2005
    595
    Re: Measuring Circumference using alphacam
    Isn't that usually done in the CAD program rather than the CAM program?
    Aug 2023
    I draw in Alphacam- it is very similar to Autocad - It just has a machine / cam function built in to the software. I can dimension radius, diameter, horizontal, vertical and aligned geometries. But cant seem to find a way to dimension circumference.
    Dec 2008
    3117
    Quote Originally Posted by BELF View Post
    You may not be able to dimension an arc, but surely you can analyse an entity and get its length
    There is not much of a requirement to have a circumference dim on a drawing, but as a circle dia X pi is an easy calc. to place into a notation.
    A bit harder for a part circle, but you should have a way to analyse features.
  1. drill at the circumference QTN250MS
    By j.koester in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-27-2012, 07:31 AM
  2. drilling on cylinder circumference
    By merraton in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-26-2011, 08:09 AM
  3. Hole Patterns on Circumference
    By leepez in forum Solidworks
    Last Post: 04-18-2011, 09:52 PM
  4. When do you stop measuring rapids in IPM and start measuring in G?
    By slashmaster in forum Benchtop Machines
    Last Post: 07-08-2009, 10:42 PM
  5. dim of circumference of cirlce?
    By bearracecars in forum Autodesk
    Last Post: 04-29-2008, 06:10 PM
