Hey, i know the information if in here scattered amoungst different posts but im still going to do it again... i am sorry though.
Im working on selecting a ball screw for a conversion im working on.
Id like to i guess understand the cause and effects of the different veriables involved.
Diameter, accuracy class, pitch, others i dont know about, with formulas.
I have estimates on dimensions
and mass on the computer at home i can add later.
The orginal mill is a Optimum BF16V, very small, it is heavily modified though, most notably a replacement saddle that is about 3 times as long, and much heavier. The original lead screws were D=14 mm. Given it is so small i may be very restricted with diameter, mainly due to the nut. My current workng estimate is a D=12mm to make it fit.
Some of the kore specific questions i suppose i have are what pitch would work best, in my case the priority is precision and repeatability.
What methods have people used to estimate weight allowance for materials, workholding, ect.
How well did it work, and more importantly when did it not work.
Similarly methods for estimating max speed.
How much benifiet is there in trying to find a D=14mm (non standard) ball screw or even 16mm, or would D=12mm be possible?
Does anyone know of good products or brands for low profile or extra small ball screw nuts to help fitting them in?
And similarly how are people finding low backlash single nuts as apposed to double, and can you recommend a product. Links incouraged.
There's alot there. If you made it this far thank you!
