So, I ran into this problem today. In the middle of a job, one of the air hoses that drives the clamps got loose, so I stopped the machine and then manually closed the air input valve. I went ahead and fixed the issue with the hose - one of the quick type fittings got stuck so the air hose did not get tightly pressed.
When I opened the air input valve I got this alarm message "2085 F. FREE BER (OFF) LOWER LS" which means the free-motion ball bearings are not in position. That makes sense, because they got out of air and probably the cylinders were not where they are supposed to be during the time they ran out of compressed air.
After I acknowledged the alarm, I pressed the start button again and expected to be able to resume work at the point where I left it, but nothing happened although there was no alarm. Finally I gave up, homed the machine, rewound the program, placed the Select keyswitch to "OFF", pressed start button and waited until the program got until to the point I had the issue before, stopped the program again, changed the Select keyswtich to "Cycle", pressed start again and finished the job.
So, my questions are:
1) Why would the program not restart after fixing the issue, considering there were no current alarms ?
2) Is there a better way to "jump back" to the place the program was ? Is it possible to bypass all the previous program lines ? I mean, the machine knew exactly where it was standing and what to do next, so cycling through all the previous program lines did not mean much. I am willing to learn a new trick line "go to line number xxxx" with a little edit at the machine´s console.
