If anyone has converted the NM-145 mill to use acorn (Centroid) electronics, please let me know your details to get it all running.
Steve Bell
Steve Bell
I did not convert a NM-145 but I did convert a Torus pro. Is there anything specific you need to know?
An acorn is a good upgrade. I will never use Mach 3 again.
In the meantime, I need to keep the machine running, but MACH3 now needs the correct XML file for the Novakon NM 145.
What may have happend is that the backup xml had been corrupted, along with the file that had recenly been in use.
I need a proper xml file for the mill until any conversion to another mill driver would be implemented.
