586,792 active members*
3,182 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Should there be a voltage across the inputs and outputs of a transformer?
    Aug 2023
    I have a Bridgeport Mill that keeps tripping its breaker. The transformer on the machine takes in 240 V and outputs 120 V for the mills spindle motor. The voltage across the two inputs of the transformer is 234 V and the voltage across the two outputs is 120 V.
    I then checked the voltage across the inputs and outputs:
    138 V across input 1 and output 1
    76 V across input 2 and output 2
    112 V across input 2 and output 1
    198 V across input 2 and output 2
    I don't know anything about electronics, does this seem right?
    Aug 2023
    Re: Should there be a voltage across the inputs and outputs of a transformer?
    Dec 2013
    5717
    The mill motor runs on 230V, 3 phase. Input to the transformer would be 230V and output would be 115V. You would not measure across the input to the output.
    Has this mill been running or is this a new install?
    Jim Dawson
    Sandy, Oregon, USA
