586,675 active members*
2,971 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal monitor colors
    Hi everyone
    I replaced the old crt monitor with a new one lcd ( fadal vmc15 1995)
    But the color of the letters is white
    Is there a way to change the color to green?
    Oct 2008
    1637
    Re: Fadal monitor colors
    They had a couple different display cards. If you had just the old monochrome CRT with black background and green letters, then you're stuck with black background and white letters. I believe the green was the default/only color for the old green crt's (they didn't have color built in, that was just their design). Later they had a color CGA I think, display card that looked much better and honestly, I don't know if it's as simple as using the later card and get a little better display. I'm not sure how CGA would look on the VGA monitor tho.
    Sorry I wasn't much help. I'm just going from my old memory here. Maybe someone else can tell us different.
    Quote Originally Posted by rwskinner View Post
    Thank you for the good information
    you are right
    Aug 2009
    1573
    ...some type of converter like this Monochrome>VGA converter might work to change Text color for you.
    https://hackaday.io/project/166041-monochromevga
    DJ
    Oct 2008
    1637
    Good idea, but then I think you would have to add a BNC to VGA adapter, then put this inline with that. Remember Fadal is using the BNC output.
  1. 1998 Fadal 4020 Monitor
    By JoBwan in forum Fadal
    Last Post: 10-09-2016, 08:47 PM
  2. Retrofit LCD Monitor for FADAL CNC88, CNC88HS
    By monitorexperts in forum News Announcements
    Last Post: 04-16-2015, 01:59 AM
  3. Fadal VMC20 Monitor Problems
    By WeTDrEaM in forum Fadal
    Last Post: 07-13-2013, 04:48 AM
  4. Monitor Replacement on Fadal 2016 - Need Help
    By WmGuildenstern in forum Maintenance DIY Discussion
    Last Post: 12-07-2012, 06:33 PM
