586,968 active members*
4,428 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki HITEC-TURN 20 SII (Seiki Multi) - Putty Terminal
Results 1 to 8 of 8
    Aug 2023
    Hello,
    We have a Hitachi Seiki HITEC-TURN 20 SII which uses the Seiki Multi control panel.
    We are trying to allow users to import/export programs from a laptop, we have the Putty terminal installed with a USB-RS232 connector and we have tried the following settings (separated by a /) but they have not worked, any ideas on if this is possible and if so what have I gotten wrong?
    Putty Terminal:
    Speed(baud): 9600 / 4800 / 2400
    Data Bits: 8 / 7
    Stop Bits: 2 / 1
    Parity: None / Even
    Flow Control: XON/XOFF / None
    Seiki Panel:
    Stop Bits: 2 / 1
    Control: Used / Available
    We are not attached to using Putty so if there is some other terminal interface that works i would be interested in that too, any help is greatly appriciated.
    Aug 2009
    1573
    Re: Hitachi Seiki HITEC-TURN 20 SII (Seiki Multi) - Putty Terminal
    ...9600 7 E 1 is most common to use with Software Handshake XON/XOFF. Other problems maybe causing your issue. Format of the Start and Finish of the program is one thing...Comm Port number the USB/PC is using also double check. If, you hold down the Windows Key and Hit R...the Run window will open then type "devmgmt.msc" then hit Enter to check Comm Port settings. Also, what Serial Cable wiring are you using CNC to USB?
    Post your Program if, you can would help.
    DJ
    Dec 2009
    542
    Hello
    What multi control? LX3 or i80?
    It’s probably just a setting issue but I have had some issues with USB to RS232 adapters.
    You can PM me your email and I’ll assist further
    John
    Aug 2023
    The putty terminal opens so i am getting the right com port, if i short the pins out then i get the echo reply, just nothing in or out of the machine iteself.
    The cable i am using is: https://www.amazon.co.uk/dp/B07ZJ673...roduct_details
    Not sure what you mean by post your program... unless you mean what i am trying to upload.
    So far i have only tried to download the existing programs from the machine which doesnt output anything in the terminal.
    Aug 2009
    1573
    ...so, which Comm Port is the USB unit? Is the software installed ok? it should be listed in Device Manager with comm number.
    Aug 2009
    1573
    ...get a tester of some kind with led lights..
    https://www.zoro.com/allen-tel-rs232...pping%20clicks
    and you might need a Null modem cable/converter
    https://en.wikipedia.org/wiki/Null_modem
    good luck,
    DJ
    Jan 2011
    30
    I wrote a simple program that transfers programs to and from a LX2 Multi control, if you'd like it it may work for you/give you more info on what you need to do to get your own program running... Don't know if it'll apply to your newer than my control, but like I said, it's quite simple.
    Aug 2023
    Got it working using this terminal:
    https://cadem.com/free-dnc-download/
    BR 9600
    Parity Even
    Data bits 7
    Stop bits 1
    handshake: software
  1. Hitachi Seiki HITEC-TURN 20SII Error
    By tomalexander in forum Hitachi Seikis
    Last Post: 10-26-2020, 11:02 PM
  2. Hitachi Seiki Hitec Turn HT20SII (Alarm # 543)
    By hayder in forum CNC Machine Related Electronics
    Last Post: 02-23-2017, 05:40 AM
  3. HITACHI SEIKI HITEC-TURN 25S LATHE
    By mikeymgs in forum Community Club House
    Last Post: 09-27-2013, 08:48 PM
  4. Hitachi seiki Hitec turn Ht 20/25
    By rai in forum Fanuc
    Last Post: 09-22-2013, 12:13 PM
  5. Hitachi Seiki Hitec - Turn 20S Help
    By fboling in forum Hyundai Kia
    Last Post: 09-18-2012, 08:53 PM
