586,080 active members*
3,706 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Help Please:- Stepper Not Changing Direction
    Hi
    I have nearly finished the control side of my router build, I have had my stepper motors running ( not connected to anything mechanical just running on my bench) everything seemed ok so started to concentrate on the mechanical design/build. I have not had my steppers running for a while so tonight I thought I would give them a run, I am using Mach 3, Gecko 210's,
    CNC4PC breakout board, all the settings in MACH 3 for all three drives are exactly the same. I started to jog the axis one at time +/- direction when I noticed that my X axis was not changing direction from + to - I held down the - direction key the DRO in MACH was saying it was going in a - direction then the motor locked up, I released the key and pressed the - key again this time it went in the - direction. I then pressed the + key the motor changed direction no problem, pressed the - key again the motor continued to go in the + direction then locked again.
    The above problem only seems to be when changing from the + direction to the - direction and only on my x axis.
    The first thing I tried was changing the motor, problem still persisted. I then changed the Step/Direction pins in MACH 3 from my X axis to my Y axis (thinking behind this was to eliminate my PC and breakout board) the problem still persisted but now obviously when I press the Y axis button.
    The only common thing that I can think of at the moment, is the Geko drive unless someone out there has had a similar problem and can point me in a different direction and hopefully help me rectify the problem.
    Thanks in advance
    Andy
    Sorted
    Thanks to Jerry (CJL5585) the above problem now seems to be sorted.
    THANKS JERRY :banana:
  1. Stepper turns only one direction
    By jhowelb in forum Stepper Motors / Drives
    Last Post: 10-04-2007, 01:52 AM
  2. motor changing direction by iteself using picstep
    By oliverthepig in forum CNC Machine Related Electronics
    Last Post: 04-30-2007, 10:11 AM
  3. stepper motors turn only one direction
    By Mike Boarman in forum CNC Machine Related Electronics
    Last Post: 11-24-2006, 11:43 PM
  4. Stepper only going in one direction?
    By ScuD in forum Stepper Motors / Drives
    Last Post: 12-09-2005, 12:28 PM
  5. Stepper rough 1 direction
    By randyf1965 in forum CNC Machine Related Electronics
    Last Post: 05-25-2005, 08:17 PM
