Hello all,
I'm finally acquiring a 24"x36" granite surface plate, and I don't really care for the factory stand designs so I'm endeavoring to build my own. I've looked at the factory data sheet for building your own stand, and downloaded a CAD model for one of the correct size from McMaster (gotta love their CAD library), so I'm confident I'll have the 3 points in the right place (will verify before welding those bits) and the clearance for the "oops" corners will be correct and so on. What I'm not confident about is what Fusion's static analysis is telling me with regard to deflection.
I modeled the tubing as hollow with the correct wall thickness (3/16"), set the material data for A500 steel, simplified the casters as the fixed faces and put an 800 lb/f load distributed on the top face of the "granite". The plate itself weighs about 600 pounds so that gives me about 200 pounds of master squares, the subject material and so on. With 2" square tubing the maximum deflection at the single suspension point for the plate it shows 0.003392", and with 3" square tubing it shows 0.001178" at that same point.
I'm not an engineer I just jumped in over my head on the whole simulation thing, so do the results seem at least plausible and if so is ~3.4 thou deflection with the 2" tube well within reason or is 3" tube at ~1.2 thou more than 2x "better" and a definite advantage of some sort for measuring things or is deflection not a big deal as it doesn't affect the plane of the surface plate? Or did I botch the simulation and the numbers look bogus (a definite possibility, perhaps hard to assess from the information provided though)...
I would appreciate any feedback on how concerned I should be about the menacing red colored image and associated range of deflection for a surface plate stand application.
