586,537 active members*
2,828 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > G02/G03 Issues - Okuma LNC8C Cadet
Results 1 to 1 of 1
    Jun 2023
    47
    Exclamation G02/G03 Issues - Okuma LNC8C Cadet
    Hey all, I'm just trying to program a radius which will create a small rounded corner on the edge of my part.
    Note: I'm very new to Okuma machines but have a fair bit of operators experience.
    The machine is a Okuma Lathe Cadet LNC8C, quite old.
    I'm just trying to understand why I keep getting an alarm when I hit the G03 line.
    In reality the radius is borderline non-consequential, but I'd rather the machine produce the rounded corner opposed to having the guys do it by hand (not practical).
    Here are the lines that I have tried, without success:
    A) G03 X.898 Z-.0135 R.0135
    B) G03 X.898 Z-.0135 I0. K.0135
    C) G03 X.898 Z-.0135 L.0135
    Here are the lines prior to the error line, as well as one line which comes after, acting as the lead out:
    G01 X1.125
    G00 Z.1
    G01 X.8845 Z.0 F.01
    G03 "A"B"C"
    If there are any other data points or pieces of information that could help solve this problem I would be more than happy to provide them. Any help would be appreciated, thanks in advance!
    JL
    Re: G02/G03 Issues - Okuma LNC8C Cadet
    Your 3rd line down is incorrect, it should be G01 X.871 Z.0 F.01, not .8845. Your "X" is always double your "Z'' on a standard radius.
    Also C) option is easiest, sorry forgot that.
    Jun 2015
    4154
    hy natha
    draw a circle in cad, etc, from point xaya to xbyb, arch<180*, thus less than half
    g-code would be : G00 X=2*ya Z=xa, folowed by G02or03 X=2*yb Z=xb L=radius F=feed G95or94
    that's all ... once this works, you may mode to compensation codes, or whatever is next on your list
    is all ok ? kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Jan 2009
    55
    Try this
    G1 X.8 Z0 F.005
    G76 X X.898L-.0135
    and Z- to your next X move
