I'm playing with a leadwell tdc-450. I've gotten it to run, test cut, and move the atc only with the atc ori button. I was getting z51 and e51 errors in mdi, but I went through the FORMAT and load fixed cycles procedure here. https://en.industryarena.com/forum/mitsubishi-m-60v-meldas-330m-m01-error--137540.html
This cleared the error, but it comes back, so I'm suspecting battery issues or something else. New battery on the way.
I have the machine Params and I reloaded the fixed cycles.
When I go to macros, I see something for M6 that should load program 9001. I manually entered the atc macro as in the electrical manual to memory in 9001, I can see it, but when I try sending M6 t1 via the rs232, I get no program no. As if it can't start the atc macro. If I delete the M6 t1 from the sample program I have, it moved around and seems fine, but it does give a "p460 tape I/o error" after. Not sure of that cause yet, but figured I'd mention it. 1000006957.jpg
How do I get the program to run when M6 TX is called, or am I missing something? I've been flipping through the generic meldas 300 manual, and the electrical manual.
Issues:
-9001 program won't get called and M6 results in error p232 no program no
-p460 tape I/o error after sending rs232 program with M6 deleted, but it does move before throwing it. Sending via NCLink and 1ms line delay. I saw this comment for a meldas 520 elsewhere, so I may increase the delay "use an 2ms linesend delay and that seems to allow the buffer to stay happy but In case of the error you had before you might have to increase this delay. It's a bit of trial / error to fine tune your particular set-up."
-e51 file open error in mdi, cleared by format and reload fixed cycles, comes back. Replacing battery.
Program I tried sending:
O2000 (T)
(DATE - 20/06/2023)
(TIME - 00:19)
(T1 - 1/2 FLAT ENDMILL )
(T2 - 1/8 DRILL )
(T3 - 1/2 FLAT ENDMILL )
(OVERALL MAX - Z.25)
(OVERALL MIN - Z-.5)
G00 G17 G40 G80 ( 1/2 FLAT ENDMILL)
M06 t1
(MAX - Z.25)
(MIN - Z0.)
G00 G17 G90 G54 X2.75 Y2. S400 M03
G43 H1 Z.25
Z.2
G01 Z0. F5.
X-2.25 F15.
G03 X-1.75 Y-1.5 I0. J.5
G01 Y1.5
G03 X-2.25 Y2. I-.5 J0.
G01 X-2.75
Z.2 F25.
G00 Z.25
X-2. Y2.75
Z.2
G01 Z0. F5.
Y2.25 F15.
G03 X-1.5 Y1.75 I.5 J0.
G01 X1.5
G03 X2. Y2.25 I0. J.5
G01 Y2.75
Z.2 F25.
G00 Z.25
X2.75 Y2.
Z.2
G01 Z0. F5.
X2.25 F15.
G03 X1.75 Y1.5 I0. J-.5
G01 Y-1.5
G03 X2.25 Y-2. I.5 J0.
G01 X2.75
Z.2 F25.
G00 Z.25
X2. Y-2.75
Z.2
G01 Z0. F5.
Y-2.25 F15.
G03 X1.5 Y-1.75 I-.5 J0.
G01 X-1.5
G03 X-2. Y-2.25 I0. J-.5
G01 Y-2.75
Z.2 F25.
G00 Z.25
M05
G91 G28 Z0.
M01
G00 G17 G40 G80 G90
