587,019 active members*
5,440 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > CNC Wood Router Lollipop Bits
    Oct 2010
    18
    I need to do some slight undercutting with my CNC router on wood. Is it practical to use and milling bit to perform this task or are there better choices. Example is UNDERCUTTING END MILLS - 300° by Harvey. What have others used and if the Harvey style bit is a good choice, how do I figure appropriate feeds and speeds using a metal cutting end mill as a wood bit?
    Re: CNC Wood Router Lollipop Bits
    The best tool to use depends on the specific application.
    As a general rule, you can get away with feeds and speeds for a similar size woodworking tool.
    Jun 2021
    105
    I was looking into this as well. I use free F360, and to get this feature, I need to but a machining extension, the cost of which I can not justify (though it also adds other functionality, but none else I really need).
    I am not sure if any Vectric software can do it.
    Oct 2010
    18
    TMTronto and Ger21, thanks for the suggestions I'll look into that.
    Quote Originally Posted by TMToronto View Post
    Vectric software does not support any undercut tools.
    Jun 2021
    105
    Thank you for confirming this.
  1. CNC Wood Router Bits
    By Ronval in forum Charter Oak Automation Support Forum
    Last Post: 08-02-2014, 06:40 AM
  2. Replies: 0
    Last Post: 07-23-2012, 09:26 AM
  3. CNC Wood Router Bits Broken Reason
    By omnicnc in forum Omni CNC
    Last Post: 05-05-2012, 03:06 AM
