587,019 active members*
3,955 visitors online*
    Mar 2008
    454
    Is it worth the extra $?
    I am going to replace my 3-jaw chuck with a 4-jaw on my 4th axis cnc.
    It does not turn fast, max rotational speed is probably 120rpm at best.
    I cut both square and round stock... wood, plexi, plastic, aluminum, brass and copper.
    I have searched and searched but cannot figure out what brand my current 3-jaw chuck is:
    Attachment 493766
    I was hoping whatever company this is, has a 4-jaw model that fits the same bolt pattern of the 3-jaw.
    Attachment 493768
    But, if I cannot figure that out or there are no matching bolt pattern 4-jaw chucks, I have found two on ebay that look good.
    I only have 3.25" between center of chuck to the base plate... so a 6" jaw would crash if the jaws ever extend past the chuck diameter.
    I will just have to mill an adapter plate myself since I also havent been able to find a 1" keyed shaft matching a new chucks bolt pattern.
    This one is cost effective:
    https://www.ebay.com/itm/123457506296
    This one sounds like better quality:
    https://www.ebay.com/itm/330720133144
    So is the second one worth paying almost twice as much for?
    I'm curious if the 'self centering' only works with a higher RPM?
    I would like your guys input, maybe even a better option available?
Name:	CNC 4axis small.jpg
    Re: Is it worth the extra $?
    the second chuck looks better made and though shars sells chinese products they are known to sell decent stuff . Regardless they are both cheap compared to high quality chucks . Personally I'd go with a 4 jaw that has independent jaws and not self centering .
    The rpm rating is irrelevant when being used on a rotary . Thats more of a balancing thing for high rpm work which doesn't apply in this situation
    Mar 2008
    454
    I bought the shars, just arrived, looks good except for an error on the back plate... almost looks like a machine crash
    Fits the 1.5" square stock with plenty of base clearance and good clamping power.
  1. Replies: 9
    Last Post: 02-22-2015, 11:49 AM
  2. Extra comma
    By azerty in forum Post Processors for MC
    Last Post: 07-11-2014, 12:10 PM
  3. ZenBotCNC? Or is ShopBot Worth the extra price?
    By LaGrasta in forum Commercial CNC Wood Routers
    Last Post: 09-04-2012, 08:02 PM
  4. extra grounding?
    By cuttinloose in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-05-2012, 02:37 AM
  5. is 175 extra oz worth $10 per stepper
    By rkremser in forum Stepper Motors / Drives
    Last Post: 01-28-2008, 11:23 PM
