586,537 active members*
2,690 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Help with feeds and speeds my cuts are producing smoke
    May 2023
    6
    I’ve been running some tests on 3/4” plywood with a 5” slitting saw.
    I’ve been getting a lot of smoking when removing a small amount of material (around 1/16”) from the outside diameter of a cylinder.
    I’ve tried a high feed rate (over 1,000) and a low feed rate (around 100 and lower).
    My spindle rpms have been tested at 8k - 12k.
    Any ideas on what I should do to fix this issue?
    I’m using Fusion 360 and Mach 4
    Dec 2008
    3110
    Re: Help with feeds and speeds my cuts are producing smoke
    8-12k rpm.... seems a little too fast. The rubbing is really friction burns. It is nearly grinding speeds.
    Try bringing it back to 1-2k adjust feed accordingly, then if passable, increase speeds & feeds to gain production speeds
    Find out what cutting speeds that tools use to cut best ie HSS cutters are different to carbide, plunging cutters are different to drills.
    Mar 2009
    1982
    or ...
    plywood is actually easy to cut amongst wooden materials. We work with wood material:
    1. The top cutting speeds ( for instance, the spindle 80 000 rpm and the cutter diameter 350 mm, so it is almost 88km per minute ! ).
    2. Strong air blow to take away the dust ( and heat ) as fast as possible.
    3. Crazy sharp cutter tips.
    The combination takes away the heat faster than agregating it.
    Sure, the tool and spindle balance at these speed is very important, otherwise the tool blows as a granade.
    May 2023
    6
    The specs on my cutter are;
    "3500-4300 rpm at a feed of 20""-100"" per minute for your application."
    I ran some tests:
    4300 at 100 feed rate and 10,000 sfm Result: smoking when making a cut
    3500 at 100 feed rate and 10,000 sfm cutter Result: stops on wood during cutting
    4300 at 50 feed rate and 10,000
    Any ideas what to try next in terms of adjusting my rpm/feed rate/sfm?
  1. Laser cutter producing dotted line cuts edges are very rough even when cut completely
    By worldspawn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2020, 05:13 AM
  2. Feeds and depth of roughing cuts:
    By ruawake in forum Tormach Personal CNC Mill
    Last Post: 04-08-2013, 08:16 PM
  3. Speeds And Feeds
    By John H in forum MetalWork Discussion
    Last Post: 12-09-2008, 04:10 AM
  4. speeds and feeds
    By bdrmachine in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-12-2008, 02:15 PM
  5. Speeds and Feeds
    By wdp67 in forum Benchtop Machines
    Last Post: 07-10-2007, 08:06 AM
