586,698 active members*
3,139 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, what is G145 on lathe ?
    Jun 2015
    4155
    hello please, i wish for g145 informations; seems to be w related / kindly
    Re: please, what is G145 on lathe ?
    Quote Originally Posted by deadlykitten View Post
    G145 means W axis control is on.
    Aug 2011
    420
    Hi
    You can use G145 command only on two spindle models.
    There is a sample program.
    Code:
    M1 P30
    NTRAN ( PART TRANSFER AND CUTOFF )
    G50 S2500 ( MAX SPINDLE RPM )
    G0 X50 Z50 M5 ( RAPID TO TUR INDEX POS )
    X=[VPVLX-VZOFX]-.001 Z=[VNVLZ-VZOFZ]+.001 T0300 M289 M89 M77
    G145
    W=[VPWTP-VZOFW]
    M288 M247
    M249
    M151 G97 S2400 M3 M76
    W.5
    (G29 PW=80)
    G94 G1 W-.3 F300 ( CHANGE AS REQUIRED - FEED ON TO PART )
    M248
    G28
    M185
    M84
    G1 W.669+.158 F300( CHANGE AS REQUIRED - PULL TO CUTOFF POS )
    M83
    M88
    M184
    G0 G95 Z.02 T0303 M8
    X.88 ( X-POS CUTOFF TOOL )
    G1 X-.08 F.005
    G29 PW=80
    G94 W2 F300
    G95
    G28
    G0 X50 W10 M9
    M150
    M246
    X50 Z50 W50 T0101
    G144
    M1 P40
    NEND
    "Imagination is more important than knowledge."
    Apr 2009
    1262
    Kurmay is spot on...
    G144 W-axis control OFF command
    G145 W-axis control ON command
    This command allows control of the sub spindle (W) axis from a program using W commands to move it. It is typically used when transferring a part to the sub spindle.
    G145 must be issued from both A and B turrets so that they agree they will now use W positioning. (works like a P-code for timing)
    Once finished with W moves, use G144 to turn off W positioning.
    Notice X, Z, and W commands can be used.. the X and Z for controlling the cutoff, and the W for controlling the sub (W) axis positioning for W approach, then gripping, then W retract (with torque sensing if desired) then retract to W + limit.
    Best regards,
    Experience is what you get just after you needed it.
    Jun 2015
    4155
    Hello at this moment i can transfer-cut, or move w, without 145, on genos p300
    as i see it, if 145 only allows w positioning, then it acts like a safety interlock on some older controls ... so i am curios, maybe is more to it ?! I dont know ... like maybe there are some w tricks, accesible only through 145 ?
    also may be only an extralayer of protection, as okuma considers safety 1st, and now they no longer require it ?
    this just crossed my mind : w positioning is only posible in g140, so could it be that g145 allows w moving when 2nd spindle is master ?
    please mr wizard, will you develop this a bit ? kindly
  1. Replies: 7
    Last Post: 03-31-2019, 02:19 AM
  2. Replies: 4
    Last Post: 05-03-2018, 04:14 PM
  3. Replies: 0
    Last Post: 05-05-2017, 06:45 PM
  4. CAD/CAM for 3-in-1 lathe/mill combo with lathe spindle stepper motor
    By KevMoto in forum Uncategorised CAM Discussion
    Last Post: 04-30-2014, 08:59 PM
  5. Replies: 3
    Last Post: 04-18-2009, 06:27 PM
