586,840 active members*
2,177 visitors online*
Results 1 to 2 of 2
    Dec 2005
    47
    VF2 Serial port problems
    I just purchased a new to me 2000 Haas VF2. The top serial port is physically missing. I initially tried to upload programs through the second serial port but had no luck communicating and then come to find out Haas says only the top serial port is for file transfer. Inside the cabinet I can see a dangling ribbon cable (see pictures) and I am assuming it is supposed to go to the missing serial port PCB. Hoping to just buy a new serial PCB from Haas and plug it into that cable but the label on the cable says "RS232 video". Any insight to this problem would be greatly appreciated.
    Thanks!
    Mar 2010
    1852
    Re: VF2 Serial port problems
    I have a spare if I can find. I can send it to you. PM me. I believe they are the same so you can just hook the RS232 cable to the one that is there.
    Mike
  1. 9 pin serial port to parrallel port
    By erkiwi in forum DeskCNC Controller Board
    Last Post: 11-21-2019, 07:33 AM
  2. serial port
    By willfly4food in forum Gecko Drives
    Last Post: 05-22-2012, 05:16 PM
  3. Serial port Help
    By machine_nut in forum CNC Machine Related Electronics
    Last Post: 06-11-2009, 12:18 AM
  4. VF2 Haas need diagram for serial
    By XYZ machine in forum DNC Problems and Solutions
    Last Post: 10-29-2008, 05:15 AM
  5. serial port
    By lamicron in forum Computers / Desktops / Networking
    Last Post: 12-18-2007, 05:42 PM
