586,817 active members*
7,353 visitors online*
    Jan 2013
    73
    Question KFLOP to VFD 0-10V
    Good day, I would like to connect KFLOP to VFD of the 18000rpm ATC spindle.
    I used JP6 pin7 IO28 on KFLOP as PWM output and connected it to (PWM to Analog (0-10V) Converter Module) (example link: https://opencircuit.shop/product/pwm...nverter-module)
    When I use the Digital IO screen screen and set the bit HIGH I get the max RPM on my spindle about 600HZ
    How should I set the Tool Setup Screen for S on Kmotion so I can use S1000 for 1000rpm, does it need to be in C program or can I do it with DAC option?
    If the only option is with C program, can you help me with C program example?
    Thank you very much.
    Best regards.
    Attachment 492810
    May 2006
    4047
    Re: KFLOP to VFD 0-10V
    Yes a C Program is required.
    See the SpindlePWM.c and SpindlePWMoff.c examples
    Since you are using PWM #2 instead of #0 and each PWM has 2 control registers add 2x2=4 to the FPGA Addresses like this:
    Code:
    	FPGA(IO_PWMS+2*2+1) = 1;    // enable the PWM
    	FPGA(IO_PWMS+2*2)   = pwm;  // set the PWM
    You might also read this Thread. Although it relates to Mach3 the technique is the similar.
    TK
    http://dynomotion.com
    24223
    Can Kflop PWM spindle control go down to a freq of 20Hz?
    May 2006
    4047
    Hi Al,
    254Hz is the minimum for the 8-bit hardware PWMs.
    But Software (User Call Back) can switch an IO with resolution of 90us. At 20Hz that provides a resolution of 0.18%
    Our new Kogna Controller has Hi-Resolution PWMs clocking at 228MHz with 32-bit Period and Pulse registers so can do most any frequency.
    TK
    Jan 2013
    73
    Good day Tom, and thank you for fast reply.
    I did try with C program but it doesn`t work.
    CODE:
    #include "KMotionDef.h"
    #define MAX_RPM 18000.0f
    // drive PWM 2 as spindle
    // PWM 2 is KFLOP IO bit #28
    // JP6 Aux#1 Pin 7
    main()
    int pwm;
    float speed = *(float *)&persist.UserData[0]; // value stored is actually a float
    pwm = speed/MAX_RPM * 255.0f;
    if (pwm > 255) pwm=255; // limit to max pwm value
    printf("Spindle Set to %f pwm %d\n",speed, pwm); // print the desired speed
Name:	KFLOP SPINDLE2.jpg
    Also I have another question. I believe since I set pins 26, 27, 28 as outputs my machine has gone mad.
    In the middle of the program one of the slaved axis doesn`t follow the other. I tried couple of time with VFD ON, with VFD unplugged and the machine always did the same.
    Then I unchecked the 26,27,28 outputs in DIGITAL I/O screen and it seems to work now.
    Do I need to install filters capacitors on outputs also? Or any other suggestion?
    Thank you.
    Jan 2013
    73
    Today I tested machine some more and the gantry Y axis is acting weird.
    In the middle of program they started to move sporadically.
    Could there be something wrong with the INIT file?
    INIT:
    // Configuration and Homing program for a 3 axis System
    // Limit switches are disabled and used as a home switch
    // then they are re-enabled
    main()
    DefineCoordSystem(0,1,3,-1);
    //Define XYZ coordinated motion axes
    //place to save limit switch settings
    //int SaveXLimits;
    //int SaveY1Limits;
    //int SaveY2Limits;
    //int SaveZLimits;
    //int SaveALimits;
    //int SaveCLimits;
    //DisableAxis(0); //X
    //DisableAxis(1); //Y1
    //DisableAxis(2); //Y2
    //DisableAxis(3); //Z
    //DisableAxis(4); //A
    //DisableAxis(5); //C
    // Set the axis parameters here
    // after everything is configured in the KMotion Screens
    // use copy C Code to clipboard on the configuration screen
    // then paste here. Repeat for each axis
    //X - POPRECNO
    ch0->InputMode=NO_INPUT_MODE;
    ch0->OutputMode=STEP_DIR_MODE;
    ch0->Vel=192000;
    ch0->Accel=1e+07;
    ch0->Jerk=1e+07;
    ch0->P=0;
    ch0->I=0;
    ch0->D=0;
    ch0->FFAccel=0;
    ch0->FFVel=0;
    ch0->MaxI=100;
    ch0->MaxErr=100;
    ch0->MaxOutput=100;
    ch0->DeadBandGain=0;
    ch0->DeadBandRange=0;
    ch0->InputChan0=0;
    ch0->InputChan1=0;
    ch0->OutputChan0=8;
    ch0->OutputChan1=0;
    ch0->MasterAxis=-1;
    ch0->LimitSwitchOptions=0x115;
    ch0->LimitSwitchNegBit=0;
    ch0->LimitSwitchPosBit=0;
    ch0->SoftLimitPos=1e+09;
    ch0->SoftLimitNeg=-1e+09;
    ch0->InputGain0=0;
    ch0->InputGain1=1;
    ch0->InputOffset0=0;
    ch0->InputOffset1=0;
    ch0->OutputGain=1;
    ch0->OutputOffset=0;
    ch0->SlaveGain=1;
    ch0->BacklashMode=BACKLASH_OFF;
    ch0->BacklashAmount=0;
    ch0->BacklashRate=0;
    ch0->invDistPerCycle=1;
    ch0->Lead=0;
    ch0->MaxFollowingError=1000000000;
    ch0->StepperAmplitude=20;
    ch0->iir[0].B0=1;
    ch0->iir[0].B1=0;
    ch0->iir[0].B2=0;
    ch0->iir[0].A1=0;
    ch0->iir[0].A2=0;
    ch0->iir[1].B0=1;
    ch0->iir[1].B1=0;
    ch0->iir[1].B2=0;
    ch0->iir[1].A1=0;
    ch0->iir[1].A2=0;
    ch0->iir[2].B0=0.000769;
    ch0->iir[2].B1=0.001538;
    ch0->iir[2].B2=0.000769;
    ch0->iir[2].A1=1.92081;
    ch0->iir[2].A2=-0.923885;
    //EnableAxisDest(0,0);
    //Y1 - LIJEVO
    ch1->InputMode=NO_INPUT_MODE;
    ch1->OutputMode=STEP_DIR_MODE;
    ch1->Vel=192000;
    ch1->Accel=1e+07;
    ch1->Jerk=1e+07;
    ch1->P=0;
    ch1->I=0;
    ch1->D=0;
    ch1->FFAccel=0;
    ch1->FFVel=0;
    ch1->MaxI=100;
    ch1->MaxErr=100;
    ch1->MaxOutput=100;
    ch1->DeadBandGain=1;
    ch1->DeadBandRange=0;
    ch1->InputChan0=0;
    ch1->InputChan1=0;
    ch1->OutputChan0=9;
    ch1->OutputChan1=0;
    ch1->MasterAxis=-1;
    ch1->LimitSwitchOptions=0x115;
    ch1->LimitSwitchNegBit=1;
    ch1->LimitSwitchPosBit=0;
    ch1->SoftLimitPos=1e+09;
    ch1->SoftLimitNeg=-1e+09;
    ch1->InputGain0=0;
    ch1->InputGain1=1;
    ch1->InputOffset0=0;
    ch1->InputOffset1=0;
    ch1->OutputGain=1;
    ch1->OutputOffset=0;
    ch1->SlaveGain=1;
    ch1->BacklashMode=BACKLASH_OFF;
    ch1->BacklashAmount=0;
    ch1->BacklashRate=0;
    ch1->invDistPerCycle=1;
    ch1->Lead=0;
    ch1->MaxFollowingError=1000000000;
    ch1->StepperAmplitude=20;
    ch1->iir[0].B0=1;
    ch1->iir[0].B1=0;
    ch1->iir[0].B2=0;
    ch1->iir[0].A1=0;
    ch1->iir[0].A2=0;
    ch1->iir[1].B0=1;
    ch1->iir[1].B1=0;
    ch1->iir[1].B2=0;
    ch1->iir[1].A1=0;
    ch1->iir[1].A2=0;
    ch1->iir[2].B0=0.000769;
    ch1->iir[2].B1=0.001538;
    ch1->iir[2].B2=0.000769;
    ch1->iir[2].A1=1.92081;
    ch1->iir[2].A2=-0.923885;
    //EnableAxisDest(1,0);
    //Y2 - DESNO
    ch2->InputMode=NO_INPUT_MODE;
    ch2->OutputMode=STEP_DIR_MODE;
    ch2->Vel=192000;
    ch2->Accel=1e+07;
    ch2->Jerk=1e+07;
    ch2->P=0;
    ch2->I=0;
    ch2->D=0;
    ch2->FFAccel=0;
    ch2->FFVel=0;
    ch2->MaxI=100;
    ch2->MaxErr=100;
    ch2->MaxOutput=100;
    ch2->DeadBandGain=1;
    ch2->DeadBandRange=0;
    ch2->InputChan0=0;
    ch2->InputChan1=2;
    ch2->OutputChan0=10;
    ch2->OutputChan1=5;
    ch2->MasterAxis=1;
    ch2->LimitSwitchOptions=0x115;
    ch2->LimitSwitchNegBit=2;
    ch2->LimitSwitchPosBit=0;
    ch2->SoftLimitPos=1e+09;
    ch2->SoftLimitNeg=-1e+09;
    ch2->InputGain0=0;
    ch2->InputGain1=1;
    ch2->InputOffset0=0;
    ch2->InputOffset1=0;
    ch2->OutputGain=1;
    ch2->OutputOffset=0;
    ch2->SlaveGain=1;
    ch2->BacklashMode=BACKLASH_OFF;
    ch2->BacklashAmount=0;
    ch2->BacklashRate=0;
    ch2->invDistPerCycle=1;
    ch2->Lead=0;
    ch2->MaxFollowingError=1000000000;
    ch2->StepperAmplitude=20;
    ch2->iir[0].B0=1;
    ch2->iir[0].B1=0;
    ch2->iir[0].B2=0;
    ch2->iir[0].A1=0;
    ch2->iir[0].A2=0;
    ch2->iir[1].B0=1;
    ch2->iir[1].B1=0;
    ch2->iir[1].B2=0;
    ch2->iir[1].A1=0;
    ch2->iir[1].A2=0;
    ch2->iir[2].B0=1;
    ch2->iir[2].B1=0;
    ch2->iir[2].B2=0;
    ch2->iir[2].A1=0;
    ch2->iir[2].A2=0;
    //EnableAxisDest(2,0);
    //Z
    ch3->InputMode=NO_INPUT_MODE;
    ch3->OutputMode=STEP_DIR_MODE;
    ch3->Vel=128000;
    ch3->Accel=1e+07;
    ch3->Jerk=1e+07;
    ch3->P=0;
    ch3->I=0;
    ch3->D=0;
    ch3->FFAccel=0;
    ch3->FFVel=0;
    ch3->MaxI=100;
    ch3->MaxErr=100;
    ch3->MaxOutput=100;
    ch3->DeadBandGain=0;
    ch3->DeadBandRange=0;
    ch3->InputChan0=0;
    ch3->InputChan1=3;
    ch3->OutputChan0=11;
    ch3->OutputChan1=7;
    ch3->MasterAxis=-1;
    ch3->LimitSwitchOptions=0x11a;
    ch3->LimitSwitchNegBit=0;
    ch3->LimitSwitchPosBit=3;
    ch3->SoftLimitPos=1e+09;
    ch3->SoftLimitNeg=-1e+09;
    ch3->InputGain0=0;
    ch3->InputGain1=1;
    ch3->InputOffset0=0;
    ch3->InputOffset1=0;
    ch3->OutputGain=1;
    ch3->OutputOffset=0;
    ch3->SlaveGain=1;
    ch3->BacklashMode=BACKLASH_OFF;
    ch3->BacklashAmount=0;
    ch3->BacklashRate=0;
    ch3->invDistPerCycle=1;
    ch3->Lead=0;
    ch3->MaxFollowingError=1000000000;
    ch3->StepperAmplitude=20;
    ch3->iir[0].B0=1;
    ch3->iir[0].B1=0;
    ch3->iir[0].B2=0;
    ch3->iir[0].A1=0;
    ch3->iir[0].A2=0;
    ch3->iir[1].B0=1;
    ch3->iir[1].B1=0;
    ch3->iir[1].B2=0;
    ch3->iir[1].A1=0;
    ch3->iir[1].A2=0;
    ch3->iir[2].B0=1;
    ch3->iir[2].B1=0;
    ch3->iir[2].B2=0;
    ch3->iir[2].A1=0;
    ch3->iir[2].A2=0;
    //EnableAxis(3,0);
    // enable all 3 axes and begin servoing where we are
    EnableAxis(0); //X
    EnableAxis(1); //Y1
    EnableAxis(2); //Y2
    EnableAxis(3); //Z
    //EnableAxis(4);
    //EnableAxis(5);
    //SetBitDirection (26,1); // set bit as output SPINDLE CW
    //SetBitDirection (27,1); // set bit as output SPINDLE CCW
    //SetBitDirection (28,1); // set bit as output SPINDLE RPM
    HOMING:
    main()
    int SaveXLimits;
    int SaveY1Limits;
    int SaveY2Limits;
    int SaveZLimits;
    //int SaveALimits;
    //int SaveCLimits;
    //X - POPRECNO
    ch0->Vel=192000;
    ch0->Accel=1e+07;
    ch0->Jerk=1e+07;
    ch0->P=0;
    ch0->I=0;
    ch0->D=0;
    ch0->FFAccel=0;
    ch0->FFVel=0;
    ch0->MaxI=100;
    ch0->MaxErr=100;
    ch0->MaxOutput=100;
    ch0->InputChan0=0;
    ch0->InputChan1=0;
    ch0->OutputChan0=8;
    ch0->OutputChan1=0;
    ch0->MasterAxis=-1;
    ch0->InputGain0=0;
    ch0->InputGain1=1;
    ch0->OutputGain=1;
    ch0->SlaveGain=1;
    ch0->Lead=0;
    ch0->iir[0].B0=1;
    ch0->iir[0].B1=0;
    ch0->iir[0].B2=0;
    ch0->iir[0].A1=0;
    ch0->iir[0].A2=0;
    ch0->iir[1].B0=1;
    ch0->iir[1].B1=0;
    ch0->iir[1].B2=0;
    ch0->iir[1].A1=0;
    ch0->iir[1].A2=0;
    //Y1 - LIJEVO
    ch1->Vel=192000;
    ch1->Accel=1e+07;
    ch1->Jerk=1e+07;
    ch1->P=0;
    ch1->I=0;
    ch1->D=0;
    ch1->FFAccel=0;
    ch1->FFVel=0;
    ch1->MaxI=100;
    ch1->MaxErr=100;
    ch1->MaxOutput=100;
    ch1->InputChan0=0;
    ch1->InputChan1=0;
    ch1->OutputChan0=9;
    ch1->OutputChan1=0;
    ch1->MasterAxis=-1;
    ch1->InputGain0=0;
    ch1->InputGain1=1;
    ch1->OutputGain=1;
    ch1->SlaveGain=1;
    ch1->Lead=0;
    ch1->iir[0].B0=1;
    ch1->iir[0].B1=0;
    ch1->iir[0].B2=0;
    ch1->iir[0].A1=0;
    ch1->iir[0].A2=0;
    ch1->iir[1].B0=1;
    ch1->iir[1].B1=0;
    ch1->iir[1].B2=0;
    ch1->iir[1].A1=0;
    ch1->iir[1].A2=0;
    //Y2 - DESNO
    ch2->Vel=192000;
    ch2->Accel=1e+07;
    ch2->Jerk=1e+07;
    ch2->P=0;
    ch2->I=0;
    ch2->D=0;
    ch2->FFAccel=0;
    ch2->FFVel=0;
    ch2->MaxI=100;
    ch2->MaxErr=100;
    ch2->MaxOutput=100;
    ch2->InputChan0=0;
    ch2->InputChan1=2;
    ch2->OutputChan1=5;
    ch2->MasterAxis=1;
    ch2->InputGain0=0;
    ch2->InputGain1=1;
    ch2->OutputGain=1;
    ch2->SlaveGain=1;
    ch2->Lead=0;
    ch2->iir[0].B0=1;
    ch2->iir[0].B1=0;
    ch2->iir[0].B2=0;
    ch2->iir[0].A1=0;
    ch2->iir[0].A2=0;
    ch2->iir[1].B0=1;
    ch2->iir[1].B1=0;
    ch2->iir[1].B2=0;
    ch2->iir[1].A1=0;
    ch2->iir[1].A2=0;
    ch2->iir[2].B0=1;
    ch2->iir[2].B1=0;
    ch2->iir[2].B2=0;
    ch2->iir[2].A1=0;
    ch2->iir[2].A2=0;
    //Z
    ch3->Vel=128000;
    ch3->Accel=1e+07;
    ch3->Jerk=1e+07;
    ch3->P=0;
    ch3->I=0;
    ch3->D=0;
    ch3->FFAccel=0;
    ch3->FFVel=0;
    ch3->MaxI=100;
    ch3->MaxErr=100;
    ch3->MaxOutput=100;
    ch3->InputChan0=0;
    ch3->InputChan1=3;
    ch3->OutputChan1=7;
    ch3->MasterAxis=-1;
    ch3->InputGain0=0;
    ch3->InputGain1=1;
    ch3->OutputGain=1;
    ch3->SlaveGain=1;
    ch3->Lead=0;
    ch3->iir[0].B0=1;
    ch3->iir[0].B1=0;
    ch3->iir[0].B2=0;
    ch3->iir[0].A1=0;
    ch3->iir[0].A2=0;
    ch3->iir[1].B0=1;
    ch3->iir[1].B1=0;
    ch3->iir[1].B2=0;
    ch3->iir[1].A1=0;
    ch3->iir[1].A2=0;
    ch3->iir[2].B0=1;
    ch3->iir[2].B1=0;
    ch3->iir[2].B2=0;
    ch3->iir[2].A1=0;
    ch3->iir[2].A2=0;
    //EnableAxis(3,0);
    // disable the limits (first save how they were set)
    SaveXLimits = ch0->LimitSwitchOptions;
    SaveY1Limits = ch1->LimitSwitchOptions;
    SaveY2Limits = ch2->LimitSwitchOptions;
    SaveZLimits = ch3->LimitSwitchOptions;
    ch0->LimitSwitchOptions = 0; //X
    ch1->LimitSwitchOptions = 0; //Y1
    ch2->LimitSwitchOptions = 0; //Y2
    ch3->LimitSwitchOptions = 0; //Z
    EnableAxis(0); //X
    EnableAxis(1); //Y1
    EnableAxis(2); //Y2
    EnableAxis(3); //Z
    //EnableAxis(4);
    //EnableAxis(5);
    //Z-AXIS
    //HOME Z-AXIS FAST
    Jog(3,20000); // jog FAST POSITIV
    while (ReadBit(3)) ; // loop until IO bit goes high
    Jog(3,0); // stop
    while (!CheckDone(3)) ; // loop until motion completes
    DisableAxis(3); // disable the axis
    Zero(3); // Zero the position
    EnableAxis(3); // re-enable the ServoTick
    Move(3,-3200); // move 2.5mm inside the limits
    //ch3->LimitSwitchOptions = SaveZLimits;
    //HOME Z-AXIS 2nd TIME SLOWER
    Jog(3,3200); // jog slowly POSITIV
    Jog(3,0); // stop
    Move(3,-6400); // (Steps/mm = 642.5803842) move 5mm inside the limits
    ch3->LimitSwitchOptions = SaveZLimits; // restore limit settings
    //Z-AXIS END
    //HOME X-AXIS FAST
    Jog(0,-20000); // jog FAST NEGATIVE
    while (ReadBit(0)) ; // loop until IO bit goes high
    Jog(0,0); // stop
    while (!CheckDone(0)) ; // loop until motion completes
    DisableAxis(0); // disable the axis
    Zero(0); // Zero the position
    EnableAxis(0); // re-enable the ServoTick
    Move(0,3200); // move 2.5mm inside the limits
    //ch0->LimitSwitchOptions = SaveXLimits;
    //HOME X-AXIS 2nd TIME SLOWER
    Jog(0,-3200); // jog slowly NEGATIVE
    Jog(0,0); // stop
    Move(0,6400); // (Steps/mm = 646.2833146) move some amount inside the limits
    ch0->LimitSwitchOptions = SaveXLimits; // restore limit settings
    //X-AXIS END
    //Y-SQUARE START
    //HOME Y-AXIS FAST
    Jog(1,-20000); // jog FAST NEGATIVE Y1
    while (ReadBit(1) && ReadBit(2)) ; // loop until IO bit goes high
    Jog(1,0); // stop
    while (!CheckDone(1)) ; // loop until motion completes
    DisableAxis(1); // disable the axis
    Zero(1); // Zero the position
    EnableAxis(1); // re-enable the ServoTick
    Move(1,3200); // move 5mm inside the limits
    //ch1->LimitSwitchOptions = SaveY1Limits;
    //HOME Y-AXIS 2nd TIME SLOWER
    ch1->MasterAxis=-1; //DESLAVE AXIS
    //SQUARING Y1
    Jog(1,-3200); // jog Y1 slow NEGATIVE
    while (ReadBit(1)) ; // loop until IO bit goes high
    Jog(1,0); // stop
    //SQUARING Y2
    Jog(2,-3200); // jog X1 slow NEGATIVE
    while (ReadBit(2)) ; // loop until IO bit goes high
    Jog(2,0); // stop
    while (!CheckDone(2)) ; // loop until motion completes
    DisableAxis(2); // disable the axis
    ch1->MasterAxis=1; //SLAVE AXIS
    Zero(1); // Zero the position of axis 1
    EnableAxis(2); // re-enable the ServoTick
    Move(1,6400); // (Steps/mm = 646.3438727) x 5 = 5mm - move 5mm inside the limits
    ch1->LimitSwitchOptions = SaveY1Limits; // restore limit settings
    //X-SQUARE END
    DefineCoordSystem(0,1,3,-1);//Define XYZ coordinated motion axes
  1. AE200 VFD 10v analog control problem
    By FrisscoCBR in forum Spindles / VFD
    Last Post: 10-26-2021, 06:38 AM
  2. 0-10V Signal Not working w/ HY VFD
    By Wood768dGuy in forum Avid CNC
    Last Post: 03-28-2021, 11:34 PM
  3. RPI's 5v PWM to 0-10V analog for VFD
    By PropellerHat in forum OpenSource Software
    Last Post: 06-10-2020, 06:18 AM
  4. Kflop spindle PWM control -10 + 10v
    By markder13 in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-02-2014, 06:27 PM
  5. G540 > 0-10v > VFD > Spindle Speed Wobbles
    By PEU in forum Gecko Drives
    Last Post: 05-23-2012, 02:09 AM
