586,560 active members*
3,448 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > the HBS86H ENA+ input issue
Results 1 to 1 of 1
    Sep 2019
    Hi everyone
    i have the chines HBS86H driver (G-penny from AliExpress),
    when i power on the driver the motor is on break status meaning you can't move the axis manually
    the problem am facing is that i can't release the motor to be able to move it by hand (need this option in my application)
    and when an error occurs i have to turn the driver off inorder to reset it
    also when connecting the EN+ input to 24V the motor do release but the red light stays on (not blinking) is that normal
    what is the solution
    i tried changing parameters from software but i can't go online with the driver ,i tried many versions.
    kind regards
    Jun 2019
    23
    Re: the HBS86H ENA+ input issue
    Quote Originally Posted by adamscnc View Post
    Hi everyone
    kind regards
    Hi did you find the solution having same problem cheers
