I'm really new to the Warpruner THC and Mach 4.
I downloaded Sheetcam and was able to create a G code file but I can't get the torch to fire.
The machine moves to the start point where it should touch off the torch tip?? Really not sure.
G code stops at line 32.
I get a message in the history bar "Probing signal active, Cannot continue.
I'm assuming the torch is supposed to drop down and contact the material back off and fire?
I do not have a floating head. I'm assuming the Warprunner is Ohmic and uses connection between the torch shield and the work (plate/metal) to sense the touch off?
Any ideas?
Here's the g code. hope it helps.
Thanks all!
