I'm learning Mach 4 after nearly 20 years with Mach 2/3.
Did the "Go to Zero button" vanish or maybe I'm just not looking in the right place?
also,
Is there a way to set up the keyboard jogs as automatic when starting Mach 4 instead of having to enable them every time.?
Mach 3 would also remember your machine's position when you shut it down. I think it is called "persistent DRO's"?
I have an I Mach Pendant (model P1AS) I haven't connected it to my new machine (plasma cutter) Is there a way to enable that on bootup of Mach 4?
thanks in advance everybody! :-[
