586,494 active members*
2,629 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > G code to drawing file
    Feb 2005
    117
    Is there a procedure to convert a g code file to a drawing file ?
    The g code would be created by Mach 3 digitizing wizard and
    possibly imported into bob cad for modifications.
    Apr 2013
    1899
    Re: G code to drawing file
    Quote Originally Posted by johnd View Post
    Try this:
    https://www.scorchworks.com/Blog/g-c...g-code-ripper/
    If your G-code paths represent the true edges of the part, just back plot it in Bobcad. Then save the vectors on your screen to a dxf. I might Though realistically this would only give you one view of the part at a time. Probably easier to just re-draw it.
  1. Need drawing to DXF file help
    By odorf in forum Uncategorised CAD Discussion
    Last Post: 09-27-2021, 11:07 PM
  2. How do you convert STL file from 3D printer to G-code or a CNC desktop mill file
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 01-25-2015, 08:37 PM
  3. Original Drawing Template File
    By Starleper1 in forum Solidworks
    Last Post: 09-02-2012, 02:01 AM
  4. getting a file from the drawing to the machine
    By will2027 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-21-2008, 02:32 PM
  5. Is my drawing ok? *file now attached*
    By Zamm in forum Musical Instrument Design and Construction
    Last Post: 06-26-2007, 10:17 PM
