586,983 active members*
3,090 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MastercamX5 Contour ToolPaths
Results 1 to 7 of 7
    May 2009
    1333
    Please let me understand the following:
    In McX5, Contour Toolpath / Cut Parameters we have under compensation type several choices but I always choose “Computer”
    Then we have Compensation Direction and the options are Right or Left
    My understanding is in the "Left" the endmill will cut on the outside of a line and the "Right" will cut on the inside of a line.
    So if I want to cut a square 4"x4" if I use the left I will get a 4x4 square and if I use the "right" I will get a smaller square (endmill diameter x 2).
    Is this correct?
    Thank you
    Nicolas
    Dec 2008
    3121
    Re: MastercamX5 Contour ToolPaths
    No...
    Left means ... the cutter follows the contour on the left side.. this is "climb" milling (if cutter is rotating CW)
    If the chain went CCW then left comp is placing tool inside.
    If the chain went CW, then left is placing tool on outside..
    Ie the big and small arrows when chaining... big arrow is the profile direction... small arrow is the cutter side
    Chaining direction is taken the from closest endpoint to the other end onto the next contacting entity.
    It pauses if there is a branch that a choice of direction is to be made by you.
    Hint... do not start contours in a corner as lead ins & outs will either be omitted or may cross over your profile ( if you cancel gouge checking), you can set to start at the midpoint of your 1st chain entity.. found in "lead in/out" settings of that toolpath operation.
    If the start of chain moves from your pickpoint, then you have errors on the chain ( branching, double entities, breaks, endpoints too far away to chain)
    Another hint... in toolpath parameters, the "geometry" item, you can modify, add, change startpoint etc) by r-clicking on the chain... you get another "editing" menu
    May 2009
    1333
    Have to study what you say Superman, very interesting and answers a lot of my questions
    You explain what Left will do to the cutter but how about the Right? What happens if I select the Right?
    Nicolas
    Dec 2008
    3121
    Forgot you're a wood worker... lol
    Right.... it will place the toolpath on the right side of the chained profile... so for a CW spindle rotation, you will be "up-cutting" (conventional machining)
    When using the XY offset, a positive number makes the tool stay FURTHER away from your profile, negative makes the cutter edge cut into the chain.
    This XY offset principle works for all comp types, positive being the direction the smaller arrow points (my previous post)
    Another hint... cutter comp OFF & zero offset & lead in/out OFF.... makes cutter path ON TOP of your profile...
    May 2009
    1333
    Very happy I learned what the 2 arrows mean when you chain an object, many thanks Superman.
    So you are saying “….Right.... it will place the toolpath on the right side of the chained profile... so for a CW spindle rotation, you will be "up-cutting" (conventional machining)…”
    Does this change if the chaining is CW or CCW?
    Nicolas
    Dec 2008
    3121
    Quote Originally Posted by kolias View Post
    I wanted to correctly state the operation when most times you use a standard cutter that is rotated CW when cutting.
    Now, going back to your "4x4 square". I want to upcut all item (right comp)
    I will pick on the r/h entity(line), break that line into 2 pieces, and also place a 3" circle inside the square.
    Go... 2d Contour, select chain(pick r/h entity above break point) (it should chain CCW, from the breakpoint), accept that contour. Select a tool, don't worry about other settings, as it is only an example.
    If toolpath parameters(comp type) is left, toolpath should calculate on the INSIDE going CCW.
    If comptype is right, path will be OUTSIDE going CCW...
    Remember, you chained CCW.
    Now.... select the geometry parameter of that toolpath...
    It should open the select window, r-click, and ADD chain, select the circle at 4 o'clock position, (it will chain CW)
    Accept the addition and regen the operation...
    If comptype is right, you now have toolpaths outside the square, and inside the cicle
    Next exercise... open that geometry parameter, in the window l-click drag the top chain to below the second...
    This puts the circle cut to occur before the outer square...
    Note... circles start points are initially at 3 o'clock position
    So, still wanting to learn ?..... ;-)
    You have just scratched the surface. So keep experimenting
    May 2009
    1333
    Thank you Superman for the education, very interesting.
    Nicolas
  1. Moving objects in MastercamX5
    By kolias in forum Mastercam
    Last Post: 12-14-2022, 10:25 AM
  2. Jerky Contour toolpaths
    By capmkrk in forum Haas Mills
    Last Post: 03-29-2014, 11:28 PM
  3. 2D Toolpaths - Contour - Rotate about Z axis
    By bandzim in forum Mastercam
    Last Post: 02-17-2013, 02:35 PM
  4. reversing toolpaths on surface contour
    By galaxyman7 in forum Mastercam
    Last Post: 02-21-2010, 09:50 PM
