586,546 active members*
3,310 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > 1982 MORI SEIKI MV-40 FANUC 6M SYSTEM PARAMETER LIST NEEDED
    Mar 2023
    4
    Esteemed community,
    Because I am new to this forum and the English language is not my natal, I do apologize for my writing errors and forms.
    Last month I received my first cnc vmc. This is a used, old, but well maintained machine (at least that is how it looks to me).
    After connecting the power and leveling it I tried to power on but immediately the 436 Z servo alarm comes in the screen.
    I have search the web and found some possible causes for it, I have done some procedures and/or tests as disconnecting cables, test fuses and even made the servo motor to be inspected mechanically and electrically and everything seems to be ok, but one of the possible causes according to the searches on the web, are parameters.
    Unfortunately I receive no manuals, no electrical prints, no parameters list from the seller, even though he promised the machine have these all.
    Right now I can not do anything about it after a 2,850 kilometer journey from Schaumburg Il, rigging, freight, and customs fees costs BUT to find somebody who might have the info needed.
    Any help or advice will be much appreciated.
    Thank you very much.
    Mar 2023
    Re: 1982 MORI SEIKI MV-40 FANUC 6M SYSTEM PARAMETER LIST NEEDED
    The following are some system parameters of MORI SEIKI MV-40 FANUC 6M for reference:
    Processing area:
    X-axis stroke: 1000 mm
    Y-axis travel: 510 mm
    Z-axis travel: 510 mm
    Spindle parameters:
    Spindle speed range: 60~6000 rpm
    Spindle taper: BT40
    Servo parameter:
    Servo motor model: FANUC AC SERVO MOTOR
    X/Y/Z axis feed speed range: 1~10000 mm/min
    X/Y/Z axis rapid traverse speed: 20000 mm/min
    Control system parameters:
    Controller model: FANUC 6M
    Monitor: CRT
    Memory: 64KB
    The above are just some basic parameter information, if you need a more detailed parameter list or other related information, please contact Flourish legend for more information.
    I would continue to bug the dealer who sold the machine to supply the manuals. An old machine without manuals is almost worthless unless you already know a ton of things about that particular machine.
    Don't give up. Keep after them for the manuals.
    In the mean time I hope someone here has something close to what you need.
    Your problems are probably not parameter related unless at some point the batteries died on the control and they were lost. Servo parameters are usually set once and never changed again.
    Mar 2023
    4
    bigjun,
    I thank you so much for the information and for sharing your contact information for further information.
    Mar 2023
    4
    gentlegiant,
    today I received great news, the machine dealer found the manuals, and these are on it's way to me. I thank you so much for your support.
    Mar 2023
    4
    Dear Sir,
    Better late than never, Thank you for your kind reply.
  1. Replies: 18
    Last Post: 03-14-2024, 05:22 AM
  2. Manual Needed for Mori Seiki MV 40 with Fanuc system 6M controller
    By dmeine in forum Machinery Manuals / Brochures
    Last Post: 12-22-2022, 02:44 AM
  3. Parameter List for Mori Seiki MV 40B Machine Center
    By innovativeiron in forum Mori Seiki Mills
    Last Post: 07-25-2021, 09:01 AM
  4. Mori Seiki MV55 Parameter List.
    By andyrive in forum Fanuc
    Last Post: 06-10-2020, 01:39 AM
