586,655 active members*
2,908 visitors online*
    Dec 2016
    10
    AvidCNC Surface Finish Quality
    Hi all,
    I am seeing a lot of surface quality issues on my AvidCNC machine. Using a .5 ball end mill with a .025 step over at 170ipm. I will attach a picture as an example.
    We have the AvidCNC linear rails and the AvidCNC Ballscrew Z axis. Everything seems to be pretty tight.
    This cut is in Ebony.
    Mick
    Jan 2012
    222
    Quote Originally Posted by MicFarlow View Post
    With a ball nose you have to do more passes closer together or you vary angle in repeated passes. The stepover as you have defined it is 0.637mm which is 3 times larger than most FFF 3D printers!
    So you have a choice, you can spend the time at the current stepover but varying angle and offset until it is near enough or setting your stepover to something like 0.008 inches (0.2032mm) and doing fewer passes.
    Either way it's a long, long time.
  1. Replies: 0
    Last Post: 02-24-2021, 08:41 AM
  2. Poor quality finish
    By NylonAdmiral in forum MetalWork Discussion
    Last Post: 04-27-2012, 06:05 PM
  3. Replies: 8
    Last Post: 04-16-2009, 01:39 AM
  4. Creating a quality surface finish
    By bsexton23 in forum Australia, New Zealand Club House
    Last Post: 07-28-2007, 08:02 PM
  5. Several questions all about finish quality.
    By Chris64 in forum MetalWork Discussion
    Last Post: 10-10-2006, 06:46 AM
