586,608 active members*
3,522 visitors online*
Results 1 to 7 of 7
    Jun 2013
    1041
    Tool changer question
    Tom
    I have been using the linear4toolholders
    C program adjusted for more tools to match my setups on 3 machines. Everything works great but I would like to prevent it from dropping off and picking back up a tool that is already in the spindle. Could you help me prevent a tool change when the currently loaded tool is called when the program is run over. I'm not sure what code to use or where to locate it in the toolchange program.
    Thank you
    Ben
    Sent from my E6910 using Tapatalk
    May 2006
    4047
    Re: Tool changer question
    Hi Ben,
    It should be just a comparison between the requested tool and current tool. If they're equal do nothing and return.
    Please post the tool change program you are using.
    TK
    http://dynomotion.com
    Jun 2013
    1041
    Tom
    Thank you for getting back with me. I am attaching the c program here as a .txt file.
    I have looked it over and have been trying to figure it out with no luck so far. If we can get it working it would be a big time saver
    Thank you
    BenAttachment 491838
    Jan 2013
    474
    Quote Originally Posted by bhurts View Post
    Tom
    Thank you
    A lot of high end, expensive machines will always return a tool to the magazine on power up to protect the spindle from collision or overspeed with an unbalanced tool running too fast. It also helps to check the tool in spindle register. If left even overnight, a wet or hot tool can almost seize into the spindle taper and jam up the toolchange.
    If your same tool is changed at the beginning of a program, why not simply put the last tool away before end of program or power off. Recommended to prevent tool ringing tight into the spindle taper.
    ie. Always start the machine or a program with an empty spindle.
    T0 M6 (or macro)
    M30 (or M02)
    Jun 2013
    1041
    I appreciate the advice Servtech and may consider emptying the spindle before shutdown. I still need the machine not to make unnecessary tool changes. I have been a machinist for around 25 years now and none of the machines I have used will return a tool that is already in the spindle only to pick it right back up before continuing. It is just unnecessary and confusing at times.
    Thank you
    Ben
    May 2006
    4047
    Hi Ben,
    Try adding this just before it unloads the previous tool (Line 107)
    Code:
    	if (ToolSlot == CurrentTool) return 0;  // desired tool already loaded?
    TK
    Jun 2013
    1041
    Tom
    Thank you so much! That seems to be working perfectly. If you think it's worth it you may want add that line to the example toolchange program. This will be added to all my other machines tonight. I don't anticipate any issues but if I run into any I will be sure to report it to you.
    Thank you
    Ben
  1. HELP!! Question concerning Haas umbrella Tool Changer Sensor.
    By kentdesautel13 in forum Haas Machines
    Last Post: 12-18-2020, 08:27 PM
  2. MD1 and MD3 tool changer question
    By Scrambled1 in forum HURCO
    Last Post: 12-07-2014, 10:52 PM
  3. Question - Dealing with VMC1000/22 DX32 Tool Changer
    By shaffin in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2013, 03:41 AM
  4. tool changer return question
    By Delw in forum Fadal
    Last Post: 12-02-2008, 06:54 AM
  5. Tool changer question
    By StormWerkz in forum Fadal
    Last Post: 03-31-2007, 10:34 AM
