586,546 active members*
3,288 visitors online*
    Aug 2015
    142
    Need sauter lathe help
    I bought an cnc lathe roeperwerk fanuc 3t , 1989 , and the turret have some missing parts .
    Turret is 05.480.316 .
    What i miss is the middle plate where stands the motor , the encoder , sensor , and the othe way is the pinion wich rotates main shaft of turret .
    I need some help with drawing , i make now some measurement , but i am not sure that i am right about .
    I found some photos in internet and after that i make the drawings .
    I want to make that plate from aluminum , and that pinion gear from metal after that i need to make it harder with heat treatment .
    Jan 2013
    474
    Quote Originally Posted by Andreiir View Post
    If I were you I would look for a good used turret, repair of a sauter turret is quite specialized and sauter used to employ service engineers with test rigs to repair and set them up. Just bolting on parts could be an expensive rabbit hole.
    Aug 2015
    142
    Re: Need sauter lathe help
    Here is picture of a plate that i made after a simulation in cad software , all is working now , and i can use the turret .
    The plate was made after i found 2 picture of interior of same turret type , with a new made pinion , and after i measure all the components that was making the turret .
  1. Turret Sauter
    By rkiiga in forum SERVICE FOR CNC-MACHINES
    Last Post: 01-20-2024, 10:36 AM
  2. Problem with SAUTER turret
    By corvuscorax4 in forum CNC Machine Related Electronics
    Last Post: 08-01-2017, 08:35 PM
  3. need help in sauter turret
    By sudip123 in forum Machinery Manuals / Brochures
    Last Post: 10-16-2016, 10:35 AM
