586,655 active members*
3,856 visitors online*
    Oct 2008
    1637
    Lathe Wear Offsets
    Are the wear offsets immediate, or only used by the controller on the tool change, or rest?
    In other words, say you have to fine tune an insert while boring a hole before the finish pass.
    Can you feed hold the machine, use the jog away, measure the hole, then adjust wear offset, then continue, or do you have to reset, then start the program at the beginning of the boring cycle?
    On my TL1, I can do run from here, and it will reload the offsets and go to where I left off. On the new ST15, run from here has been removed, you only have Joq Away Return, but I'm unsure if that will read any changes on the offset or wear tables.
    Oct 2008
    1637
    Re: Lathe Wear Offsets
    Since nobody seems to know or take the time to answer, I would guess the only time tool offset are read and applied is when you tell it to with the T0101 or whatever tool is called. The reason the TL works is because run from here will read all the code before the highlighted section so if you make a offset adjustment, it will be called again before motions starts. Evidently, the Haas Jog Away continue doesn't do this, which make it pretty worthless if you're measuring and making corrections or changing an insert and need to zero the wear offset.
    Dec 2008
    3111
    Put the T0101 offset call again in the finish pass section to force the adjusted offset take up.
  1. LB45 II M, OSP U100L, wear offsets
    By Aplowman in forum Okuma
    Last Post: 04-05-2024, 09:22 AM
  2. Replies: 2
    Last Post: 02-26-2021, 07:38 AM
  3. Fanuc 0T-A wear offsets locked
    By forhire in forum Fanuc
    Last Post: 07-26-2019, 12:01 AM
  4. External control of wear offsets
    By jwl300 in forum Fanuc
    Last Post: 12-22-2016, 10:56 AM
  5. Fanuc 0T-B Wear Offsets not doing anything
    By wtopace in forum Fanuc
    Last Post: 08-03-2016, 03:37 PM
