586,955 active members*
2,933 visitors online*
    Dec 2005
    33
    Wall mounting an avid router
    I would like to mount an Avid Pro cnc router vertically to the wall to save space. Anyone see any reason why this would be a problem? Perhaps I would need to go with larger steppers on the Y axis?
    Re: Wall mounting an avid router
    It should work fine, but the axis that moves vertically will definitely move slower, or at least accelerate slower. A bigger stepper may or may not help, as bigger motors tend to have even less power at higher speeds.
    Mounting work to the table can be tricky, as you're always fighting gravity.
    Jan 2012
    222
    Quote Originally Posted by sblack View Post
    I wouldn't do it. The reason is the rack and pinion system. If it was ball screw or motorcycle chain, sure. But this is rack and pinion and even flat I can push it out of square without much effort.
    Dec 2016
    53
  1. Fitting a console controller on an Avid router
    By XYZGnomon in forum CNC Machine Related Electronics
    Last Post: 08-28-2021, 07:29 PM
  2. CNC Router Parts / Avid Touch off Plate
    By wmgeorge in forum For Sale Only
    Last Post: 08-04-2020, 01:05 PM
  3. Avid CNC router in KC area?
    By chick533 in forum Avid CNC
    Last Post: 01-26-2020, 09:18 PM
