586,501 active members*
3,263 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Can FlatCAM engrave a simple path
    Mar 2023
    Hi, relatively new to CNC although I have done milled prototype circuit boards for a few years using EasyEDA+FlatCAM+Candle. This has worked well for my needs but now I would like to engrave some text and symbols in the unmilled copper layer. It is the purple I want to engrave in the attached picture.
    I'm not an expert but it seems like there is no function in FlatCAM to just let the tool go along the path defined in the gerberfile?
    Nov 2012
    154
    Re: Can FlatCAM engrave a simple path
    Funnily enough, others seem to have asked the same question and apparently the answer is "yes, but only the stupid way - by using the command line". See this: https://caram.cl/software/flatcam/tr...-with-flatcam/
    Fair warning, Flatcam 8.5 just threw an error on that for me - YMMV, or you might just need the exact version used in the linked post (v7). Good luck...
  1. Simple Software to render CNC path
    By sairfan1 in forum OpenSource Software
    Last Post: 08-04-2022, 03:12 AM
  2. F-Engrave 1.58 - Question on tool path and lifting
    By 1875 in forum OpenSource Software
    Last Post: 01-12-2017, 07:46 PM
  3. Converting simple DXF file to tool path G code
    By stevenSmidley in forum NCPlot G-Code editor / backplotter
    Last Post: 04-08-2016, 01:29 PM
  4. Simple Engrave program
    By Buzz239 in forum G-Code Programing
    Last Post: 10-30-2012, 01:14 PM
