586,999 active members*
2,974 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > I'm missing something somewhere...debugging and sound?
    Nov 2009
    15
    Question I'm missing something somewhere...debugging and sound?
    My Google-fu is either lacking, or I'm missing something somewhere. I need help finding 2 things:
    a) how do I turn debug mode on? In other words, rather than using (print, blah blah)...I want to use (debug, blah blah)...
    b) how do I get it to beep / siren / any noise at all when it's done?
    Many thanks in advance; I'm just losing hair here, there are references but no examples I can find in the documentation.
    Lee
    Apr 2018
    134
    Re: I'm missing something somewhere...debugging and sound?
    Perhaps this page will help:
    https://planet-cnc.com/category/software/
    In the Troubleshooting section is this debug example:
    Troubleshooting
    If inverter will not respond to any spindle gcode command , it indicates that something is not ok.
    Type into the MDI window the following text:
    =debug = 1
    Test the M3, M4 and M5 codes again.
    Observe the output window and the printed text.
    Nov 2009
    15
    I saw that. It doesn't seem to do anything and that applies to a specific piece of equipment, I think.
    I have a series of (print, blah blah) commands and I only wanted to show them if the debug was on; I changed one to (debug, blah blah) and now it simply doesn't show that line. I'd prefer not to have a bunch of
    O23 if [#<deeebug> EQ 1] (print, blah blah) O23 endif
    type statements (I'm not sure exactly what it would look like, but it would certainly be clunky.)
    Seems like a bad approach to the problem, so I'm figuring debug is the way to do this.
